Date/Time: Sun, 27 Sep 2026 10:36:10 +0000
drag and drop not working properly for horizontal lines
View Count: 1180
| [2016-04-25 12:06:34] |
| T29_Dev1 - Posts: 22 |
Horizontal lines that was created from study disappears when I drag it. This code I use to create the line: s_UseTool tool; tool.ChartNumber = sc.ChartNumber; tool.DrawingType = DRAWING_HORIZONTALLINE; tool.TextAlignment = DT_RIGHT; tool.AddMethod = UTAM_ADD_OR_ADJUST; tool.Color = COLOR_GREEN; tool.LineStyle = LINESTYLE_SOLID; tool.LineWidth = 2; tool.Text = "myline"; tool.BeginValue = sc.BaseDataIn[SC_HIGH][sc.ArraySize - 2]; tool.DisplayHorizontalLineValue = 1; tool.AddAsUserDrawnDrawing = 1; sc.UseTool(tool); When I create a line manually in SC, it works fine. I noticed that SC creates horizontal lines with anchor datetime != 0 and I can't set the anchor time (SC ignores it). I want to use horizontal lines to allow user to set some price level. |
| [2016-04-25 16:20:06] |
We will test this.
| [2016-04-25 17:19:32] |
| Al SC Developer - Posts: 434 |
This will be addressed in the next version.
