Date/Time: Sat, 08 Aug 2026 03:32:31 +0000
Sunday Market open
View Count: 1021
| [2016-04-25 03:23:04] |
| gmorgan111 - Posts: 121 |
I opened my platform to this evening to see how the market opened in the es ym cl and noticed that the data started at 21.33 in the es and the other markets at the approximate same time. The market on Sunday is supposed to open at 17:00 central time and always has. Could you tell me why I am getting data starting at 21.33 instead of 17:00 central time Thanks |
| [2016-04-25 03:36:20] |
Follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart There could be a couple of different causes. As you go through the instructions the cause may become apparent. In any case the missing data will be filled in. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
