Date/Time: Wed, 28 Oct 2026 21:23:15 +0000
Parallel Lines with Log Scale
View Count: 2197
[2016-04-24 16:34:06]
User76223 - Posts: 7
I cannot find a way to draw parallel lines (channel) on a Sierra Chart when using a log scale for the chart. The parallel lines are only parallel on the linear scale, not the log scale. When drawing parallel lines while using log scale, the lines do not come out parallel, but if I convert to a linear scale, they are parallel. Is there a way to draw parallel lines when using a log scale?
[2016-04-24 22:13:34]
Refer to this help topic about this:
https://www.sierrachart.com/index.php?page=doc/helpdetails34.html#LogarithmicScaleParallelLines
