Date/Time: Wed, 28 Oct 2026 21:23:16 +0000
Profile
View Count: 1131
[2016-04-22 18:21:08]
rhobbo1 - Posts: 4
With the Market profile study, is it possible to select a number of days or periods to
merge the periods rather than having to right click... merge with prior/next period?
[2016-04-22 18:33:53]
No. This is not supported. You will have to do them one by one.
Although there are keyboard shortcuts that can be used which are equivalent to the TPO shortcut menu commands. We still have to document those.
[2016-04-22 19:04:16]
rhobbo1 - Posts: 4
what are the keyboard shortcuts?
[2016-04-23 01:20:40]
We are working on documentation now for this.
[2016-04-23 01:51:14]
Here is the documentation:
https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#KeyboardShortcutsForSplittingAndMerging
[2016-04-23 02:00:17]
The other part we forgot to mention is you need to use Sierra Chart version 1400 or higher. We fixed a small problem with this.
[2016-04-23 10:18:05]
rhobbo1 - Posts: 4
is it possible to overlay the Market profile on a OHLC or Candlestick chart?
I'd like to be able to see the market profile on the same chart.
Also, IB supports continuous Futures charts. How can I display continuous charts in Sierra with the volume profile?
[2016-04-23 11:04:30]
This is not supported:
For instructions to use Continuous Futures Contract charts, refer to:
Continuous Futures Contract Charts
