Date/Time: Wed, 28 Oct 2026 22:11:38 +0000
After the last 2 updates the BE Stop doesn't work
View Count: 1506
| [2016-04-22 09:03:28] |
| JRA - Posts: 97 |
I notice from yesterday that after I updated to 1398 and 99, the move to breakeven has stopped working. I do use a negative BE level offset If you want to replicate it.
| [2016-04-22 09:06:33] |
We just did a quick test in Trade Simulation Mode and it works correctly. Including using a negative offset. Are you referring to the "BE" button on the Trade Window? So there is no modification of the stop order to the breakeven level? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-22 11:07:56] |
| JRA - Posts: 97 |
I haven't tested it on sim, live on IB from Yesterday it stopped moving my initail stop loss to the BE leve I have set it to. I didn't change anything and it worked before the update. Are you referring to the "BE" button on the Trade Window?
No I am refering where the targets tab is, and I have set on the stop all child order, step 1, type offset in ticks triggered, BE Level offset -3, Trigger offset 5.
| [2016-04-22 15:56:43] |
| JRA - Posts: 97 |
I just test it on sim and it works. It's not working live with IB.
| [2016-04-22 22:45:17] |
We see why this is happening and it will be solved in the next release.
| [2016-04-25 08:25:40] |
| JRA - Posts: 97 |
Checked today Live on DAX and everything works with the latest release. Thank you!! |
