Date/Time: Wed, 28 Oct 2026 21:23:14 +0000
Can I change/modify the name in chart "ING-STK-AEB" to only ING
View Count: 26767
[2016-04-21 20:25:01]
User134797 - Posts: 56
HI All,
To dowload data from Interactive Brokers to SierraChart there are some convention.
For example if I download "ING" the convention are "ING-STK-AEB".
Question: can I change the name to "ING" and than save it, so I can do some backtesting (the name is long).
It is not possible in SiereChart to dowmload "ING" because "ING" and "ING-STK-AEB" is not the same data/price.
Best,
Iwan
[2016-04-21 20:38:37]
You need to use the complete symbol format.
So it has to be: "ING-STK-AEB".
Date Time Of Last Edit: 2016-04-21 20:38:52
[2016-04-22 05:48:45]
Hi All
Question was:
If I already dowload the data with the right convention "ING-STK-AEB" for 1 month period.
Is it now possible to change the header "ING-STK-AEB" in only "ING". It most be possible I already dowload the data and SierrChart is disconnect.
Best,
Iwan
[2016-04-22 06:34:15]
Yes you can do that. Here are instructions:
Chart Data and Chart Data Files: Renaming Chart Data Files
