Date/Time: Wed, 28 Oct 2026 21:23:06 +0000
Options in SC
View Count: 1048
| [2016-04-21 08:19:47] |
| User12089 - Posts: 386 |
A few questions about creating charts and other data dashboards for Options in Sierra Charts: a) Does the product support Options at all - I could not see that advertised / documented explicitly anywhere lets take as an example the whole group of ES options on CME Globex: b) How do I show their real-time Options Chain dashboard - for the whole group ie all ES option quotes c) Assuming the data feed provider is IQFeed how do I create a chart in SC for specific ES option - please describe the detailed sequence of steps for SC and specific symbol names used |
| [2016-04-21 11:52:31] |
| User411334 - Posts: 38 |
+1. I am interested in this as well.
| [2016-04-21 17:31:02] |
Sierra Chart supports charting and trading individual options. Simply open a chart for the option symbol using the symbol format of the particular Data or Trading service being used. There is nothing special. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
