Date/Time: Wed, 28 Oct 2026 21:23:05 +0000
Is it Possible to define a fixed Subgraph ArraySize?
View Count: 939
| [2016-04-21 03:34:41] |
| enemyspy - Posts: 307 |
Hi I have a study that calculates an enormous amount of statistics, that I would like to make real time view-able in a practical way without having use a method to dump it to a text file so that excel or some other program can open and parse it. Its too cumbersome. Using Subgraphs with the spreadsheet study would work if I can define a static Subgraph Array Size. In this Way everything could be placed in the appropriate spreadsheet cell by plotting in Relation to sc.ArraySize-X (where x represents the cell I want) without it changing or continuing to store redundant data as the Array Size gets larger. Is there an ACSIL function for this? |
| [2016-04-21 06:16:48] |
The closest that is available is: ACSIL Interface Members - Variables and Arrays: sc.IsCustomChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
