Date/Time: Sun, 11 Oct 2026 18:54:01 +0000
REF:B Dec 16 Mar 17 Calendar Spread no data
View Count: 1116
[2016-04-19 08:30:28]
ilb59 - Posts: 3
REF:B Dec 16 Mar 17 Calendar Spread has not had any data updates since the market close on the 15th April. I have tried deleting and downloading data, but to no avail.
[2016-04-19 16:44:15]
This is a problem with the Easy Screen data feed. We need to contact them about this.
They really need to resolve this.
[2016-04-20 05:40:46]
We are contacting them about it now. We have gathered the necessary information for them.
[2016-04-20 05:44:16]
ilb59 - Posts: 3
Thank you very much for assisting - seems Easyscreen may have alot of improvements they need to make!
[2016-04-20 05:57:08]
We also now have the ability to patch missing data for ICE spreads and we have done that for this particular spread.
So if you right-click on the chart before the missing data and select Delete and Download Data, it will fill in.
[2016-04-20 06:21:43]
ilb59 - Posts: 3
Yep, that worked, thanks for the assistance!
