Date/Time: Sun, 11 Oct 2026 19:53:12 +0000
draw profiles on chart issue
View Count: 1555
[2016-04-18 20:10:08]
User771416 - Posts: 47
I have a day session only chart of the ES that plots daily bars only (a composite chart). i draw "Micro Composite" profiles on this chart as well as having an overall composite profile.
I'm just figuring things out with Sierra so i tried changing the settings on my most recent MC and have run into an issue i can't figure out.
when i started working on this chart i could right click the profile and get a small dialog box that gave me short list of options to choose from, one of which was "Volume Profile Settings" at the bottom. Now however, i get nothing when i right click on the last profile. i still get the box when i click on the other profiles i have drawn on the chart, but not the last one.
i thought i'd simply delete this last one and start over, however i can't even select it to delete it. i can right click the chart and select Study Settings and get to the settings for this profile (which is now listed separately from the other profile studies on the chart)(this one i'm referring to is listed as VbP3).
Can you tell me how to delete this profile, or why it's not accessible with a right click any longer?
[2016-04-18 21:28:52]
You can access all of the Volume by Price studies through Analysis >> Studies.
If that profile you do not get Volume Profile Settings for, was not drawn on the chart with the Draw Volume Profile tool, then that is the reason why that command is not listed for it.
