Date/Time: Sun, 11 Oct 2026 19:52:36 +0000
dynamic RSI
View Count: 2889
| [2016-04-17 14:47:43] |
| User970904 - Posts: 9 |
Hello, i cannot seem to find a dynamic RSI indicator in SC ? http://images0.tcdn.nl/dft/nieuws_dft/article23375722.ece/BINARY/original/RANDSTAD.JPG It uses BB on the RSI ? Is this possible to create in SC ? thank you |
| [2016-04-17 21:37:06] |
This is supported by using the Based On setting with the Bollinger Bands study: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Here is an example: http://www.sierrachart.com/image.php?Image=1460929008821.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-18 07:18:30] |
thank you !
| [2016-04-18 12:11:50] |
I would like these BB values in a custom study. "In your custom study function you may need to work with the results of other studies/indicators, like a Moving Average or some other study. There are several methods to accomplish this." "Use one of the Intermediate Study Calculation Functions like sc.SimpleMovAvg." Is it possible to use the BB values (based on RSI input) using this method ? The "FloatArrayIn" for the BB would then have to be the RSI array ? How do i refer the RSI array as FloatArrayIn for BB ? sc.RSI(sc.BaseDataIn[SC_LAST], sc.Subgraph[0], MOVAVGTYPE_SIMPLE, 14); sc.BollingerBands(sc.Subgraph[0].Arrays[0][sc.Index], sc.Subgraph[1], 14, 1.8, MOVAVGTYPE_SIMPLE); doesn't seem to work thank you Date Time Of Last Edit: 2016-04-18 12:35:31
| [2016-04-18 17:24:00] |
Here is the correct code: sc.RSI(sc.BaseDataIn[SC_LAST], sc.Subgraph[0], MOVAVGTYPE_SIMPLE, 14);
sc.BollingerBands(sc.Subgraph[0].Data, sc.Subgraph[1], 14, 1.8, MOVAVGTYPE_SIMPLE); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
