Date/Time: Wed, 23 Sep 2026 08:06:24 +0000
Unable to download sufficient data on monthly charts
View Count: 1834
| [2016-04-15 23:25:37] |
| User71822 - Posts: 24 |
I find that when I try to load longer term charts, such as monthly, I only get about thirty bars of data. I have checked your help files but have been unable to find a solution to the problem. Can you help? thanks peter Date Time Of Last Edit: 2016-04-16 06:58:49
| [2016-04-16 06:59:34] |
We see you are using IQFeed. Can you give us the symbol of one of these monthly charts, so we can give you the proper instructions.
| [2016-04-20 15:10:51] |
My impression is that it happens on all longer term charts. The ones I have specifically tried are: ES, SPY, MSFT and TMV. THANKS |
| [2016-04-20 17:36:21] |
In the case of stock charts, refer to this page: No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data In the case of futures charts, you need to use the continuous futures contracts symbols from IQ Feed. For example use: @ES# Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-22 16:38:28] |
As a matter of fact, I did use the continuous contract (@ES#). If I'm not mistaken, SPY is the cash index, so a continuous contract would not be relevant. Thanks |
| [2016-04-22 17:43:00] |
There is no continuous futures contract symbol for SPY. Go to one of the charts you are having a problem with and then re-download the data with Edit >> Delete All Data Download. If there still is insufficient data, post a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-22 17:43:17
| [2016-04-23 18:36:43] |
Software version: 1392 | 2016-04-22 12:14:15 Uses New Spreadsheets | 2016-04-22 12:14:15 Usage end date: 2016-06-02 | 2016-04-22 12:14:15 Enabled for: Advanced Features. | 2016-04-22 12:14:15 Enabled for: Sierra Chart Historical Data Service. | 2016-04-22 12:14:15 Allow Support for Sierra Chart Data Feeds is disabled. | 2016-04-22 12:14:15 Current selected Data/Trading service: IQFeed | 2016-04-22 12:14:15 Chart Update Interval: 500 | 2016-04-22 12:14:15 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-04-22 12:14:15 2016-04-22 12:14:22 Local computer time | 2016-04-22 12:14:15 2016-04-22 16:14:22 Local computer time in UTC | 2016-04-22 12:14:15 2016-04-22 12:14:22 Local computer time in SC Time Zone | 2016-04-22 12:14:15 2016-04-22 16:13:59 Server time in UTC | 2016-04-22 12:14:15 Local computer UTC time and Server UTC time difference: 22 seconds. | 2016-04-22 12:14:15 Program path: C:\SierraChart\ | 2016-04-22 12:14:15 Data Files path: C:\SierraChart\Data\ | 2016-04-22 12:14:15 OS Version Number: 6.2 | 2016-04-22 12:14:15 Locale Setting: C | 2016-04-22 12:14:15 Checking for new symbol settings for dtn | 2016-04-22 12:14:15 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-04-22 12:14:15 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-04-22 12:14:15 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-04-22 12:14:15 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-04-22 12:14:15 Symbol settings are up-to-date for dtn | 2016-04-22 12:14:23 Files to Open on Start up | Opening file: Chartbook128.cht | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for VXX | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 Files to Open on Start up | Opening file: Chartbook128 A.cht | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for VXX | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 Files to Open on Start up | Opening file: Chartbook128 B.cht | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for VXX | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:14:25 Files to Open on Start up | Opening file: Chartbook129.cht | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for CORN | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for SGG | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for JO | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for MSFT | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for HRL | 2016-04-22 12:14:25 IQFeed | Using primary service for historical data for FXC | 2016-04-22 12:14:25 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-04-22 12:14:25 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-04-22 12:14:25 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-04-22 12:14:25 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-04-22 12:14:25 IQFeed | Connecting. | 2016-04-22 12:17:17 IQFeed | Connecting to Admin port 9300 | 2016-04-22 12:17:17 Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-04-22 12:17:20 Socket (4) | Shutdown and closed. | 2016-04-22 12:17:20 IQFeed | Disconnected from Admin port. | 2016-04-22 12:17:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-22 12:17:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-22 12:17:20 Starting DTN IQ Feed interface software. | 2016-04-22 12:17:20 IQFeed | Disconnected. | 2016-04-22 12:17:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 12:17:20 IQFeed | Connecting. | 2016-04-22 12:17:28 IQFeed | Connecting to Admin port 9300 | 2016-04-22 12:17:28 Socket (6) | Connected. | 2016-04-22 12:17:29 IQFeed | Connected to Admin port. | 2016-04-22 12:17:29 AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2016-04-22 12:17:29 AdminMessage: S,STATS,,,0,0,1,3670489049,0,0,,,Not Connected,5.2.0.9,ptrhbg1,0,0,,0.03,0.03,, | 2016-04-22 12:17:29 AdminMessage: S,STATS,66.112.156.224,60003,500,0,1,0,0,0,Apr 22 12:17PM,,Connected,5.2.0.9,ptrhbg1,0.03,0.03,0,0.11,0.06,0, | 2016-04-22 12:17:30 IQFeed | Connecting to Level 1 port 5009 | 2016-04-22 12:17:30 Socket (7) | Connected. | 2016-04-22 12:17:30 IQFeed | Connected to Level 1 port. | 2016-04-22 12:17:30 IQFeed | Connecting to Lookup port 9100 | 2016-04-22 12:17:30 IQFeed | Connecting to Level 2 port (9200)... | 2016-04-22 12:17:30 Socket (8) | Connected. | 2016-04-22 12:17:30 IQFeed | Connected to Historical Data port. | 2016-04-22 12:17:30 IQFeed | Connected to data server. | 2016-04-22 12:17:30 Socket (9) | Connected. | 2016-04-22 12:17:30 IQFeed | Connected to Level 2 port. | 2016-04-22 12:17:30 IQFeed Level 2 error: Account not authorized for Level II | 2016-04-22 12:17:30 IQFeed | Level 2 protocol is 5.0. | 2016-04-22 12:17:30 IQFeed | Level 1 system message: KEY | 2016-04-22 12:17:30 IQFeed | Level 1 system message: SERVER CONNECTED | 2016-04-22 12:17:30 IQFeed | Level 1 system message: IP | 2016-04-22 12:17:30 IQFeed | Level 1 system message: CUST | 2016-04-22 12:17:30 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:30 IQFeed | Starting real-time market data updates for: SPY. ID: 1 | 2016-04-22 12:17:30 HD Request # 2 | Downloading Historical Daily chart data for SPY. Starting date: 2016-04-20. Service: dtn | 2016-04-22 12:17:30 HD Request # 2 | Requesting 4 days of historical daily data. RequestID: 1 | 2016-04-22 12:17:30 IQFeed | Starting real-time market data updates for: @ES#. ID: 2 | 2016-04-22 12:17:30 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:30 Intraday data recording state for symbol @ES# is set to download 'Pending'. | 2016-04-22 12:17:30 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:30 IQFeed | Starting real-time market data updates for: VXX. ID: 3 | 2016-04-22 12:17:30 IQFeed | Using primary service for historical data for VXX | 2016-04-22 12:17:30 Intraday data recording state for symbol VXX is set to download 'Pending'. | 2016-04-22 12:17:30 IQFeed | Starting real-time market data updates for: CORN. ID: 4 | 2016-04-22 12:17:30 IQFeed | Using primary service for historical data for CORN | 2016-04-22 12:17:30 Intraday data recording state for symbol CORN is set to download 'Pending'. | 2016-04-22 12:17:30 IQFeed | Starting real-time market data updates for: SGG. ID: 5 | 2016-04-22 12:17:30 IQFeed | Using primary service for historical data for SGG | 2016-04-22 12:17:30 Intraday data recording state for symbol SGG is set to download 'Pending'. | 2016-04-22 12:17:30 IQFeed | Starting real-time market data updates for: JO. ID: 6 | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for JO | 2016-04-22 12:17:31 Intraday data recording state for symbol JO is set to download 'Pending'. | 2016-04-22 12:17:31 IQFeed | Starting real-time market data updates for: FXC. ID: 7 | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for FXC | 2016-04-22 12:17:31 Intraday data recording state for symbol FXC is set to download 'Pending'. | 2016-04-22 12:17:31 HD Request # 2 | Receiving Daily data for SPY | 2016-04-22 12:17:31 HD Request # 2 | Receiving historical Daily data for SPY starting at 2016-04-20 | 2016-04-22 12:17:31 HD Request # 2 | Writing historical Daily data to the file SPY.dly | 2016-04-22 12:17:31 HD Request # 2 | Received 4 records from 2016-04-20 00:00:00 to 2016-04-21 00:00:00 (2.0 days) and wrote 2 records for SPY | 2016-04-22 12:17:31 HD Request # 2 | Daily download COMPLETE for SPY. Completion time: 1s. Unique request ID: 1 | 2016-04-22 12:17:31 Removed historical data download ID 1 | 2016-04-22 12:17:31 Delaying start of download for @ES# | 2016-04-22 12:17:31 @ES# Monthly #1 | Reloading chart. | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:31 @ES# Weekly #2 | Reloading chart. | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:31 IQFeed | Starting real-time market data updates for: MSFT. ID: 8 | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for MSFT | 2016-04-22 12:17:31 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2016-04-22 12:17:31 HD Request # 3 | Downloading Intraday chart data for @ES# to the file @ES#.scid. Service: dtn | 2016-04-22 12:17:31 HD Request # 3 | Download start Date-Time: 2016-04-22 12:08:33.000 | 2016-04-22 12:17:31 HD Request # 3 | Requesting Tick data beginning at 2016-04-22 12:08:33 US Eastern Time. | 2016-04-22 12:17:31 IQFeed | Starting real-time market data updates for: HRL. ID: 9 | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for HRL | 2016-04-22 12:17:31 Intraday data recording state for symbol HRL is set to download 'Pending'. | 2016-04-22 12:17:31 @ES# Monthly #1 | Reloading chart. | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:31 @ES# Weekly #2 | Reloading chart. | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:31 SPY Monthly #4 | Reloading chart. | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:31 SPY Monthly #11 | Reloading chart. | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:31 HD Request # 3 | Receiving historical Intraday Tick data for @ES# | 2016-04-22 12:17:31 HD Request # 3 | Receiving Intraday data for @ES# starting at 2016-04-22 12:08:33 | 2016-04-22 12:17:31 HD Request # 3 | Timestamp of first Intraday data file record written: 2016-04-22 12:08:33 | 2016-04-22 12:17:31 HD Request # 3 | Received 5078 records from 2016-04-22 12:08:33 to 2016-04-22 12:17:09 (8.6 minutes) and wrote 5078 records for @ES# | 2016-04-22 12:17:31 HD Request # 3 | Intraday download COMPLETE for @ES#. Completion time: 0s. Unique request ID: 2 | 2016-04-22 12:17:31 Removed historical data download ID 2 | 2016-04-22 12:17:31 Real-time Intraday chart data file updates started for @ES# | 2016-04-22 12:17:31 Opened cached Intraday file: C:\SierraChart\Data\@ES#.scid | 2016-04-22 12:17:31 Intraday chart data file opened for @ES# | 2016-04-22 12:17:31 HD Request # 4 | Downloading Historical Daily chart data for @ES#. Starting date: 2016-04-20. Service: dtn | 2016-04-22 12:17:31 HD Request # 4 | Requesting 4 days of historical daily data. RequestID: 3 | 2016-04-22 12:17:31 @ES# Monthly #1 | Reloading chart. | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:31 SPY Monthly #4 | Reloading chart. | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:31 SPY Monthly #11 | Reloading chart. | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:31 SPY Monthly #11 | Reloading chart. | 2016-04-22 12:17:31 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:31 HD Request # 4 | Receiving Daily data for @ES# | 2016-04-22 12:17:31 HD Request # 4 | Receiving historical Daily data for @ES# starting at 2016-04-20 | 2016-04-22 12:17:31 HD Request # 4 | Writing historical Daily data to the file @ES#.dly | 2016-04-22 12:17:31 HD Request # 4 | Received 4 records from 2016-04-20 00:00:00 to 2016-04-21 00:00:00 (2.0 days) and wrote 2 records for @ES# | 2016-04-22 12:17:31 HD Request # 4 | Daily download COMPLETE for @ES#. Completion time: 0s. Unique request ID: 3 | 2016-04-22 12:17:31 Removed historical data download ID 3 | 2016-04-22 12:17:31 Delaying start of download for VXX | 2016-04-22 12:17:31 SPY Monthly #4 | Reloading chart. | 2016-04-22 12:17:32 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:32 @ES# Monthly #1 | Reloading chart. | 2016-04-22 12:17:32 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:32 @ES# Weekly #2 | Reloading chart. | 2016-04-22 12:17:32 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:32 @ES# Monthly #1 | Reloading chart. | 2016-04-22 12:17:32 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:32 @ES# Weekly #2 | Reloading chart. | 2016-04-22 12:17:32 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:32 SPY Monthly #4 | Reloading chart. | 2016-04-22 12:17:32 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:32 SPY Monthly #11 | Reloading chart. | 2016-04-22 12:17:32 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:32 @ES# Monthly #1 | Reloading chart. | 2016-04-22 12:17:33 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 12:17:33 SPY Monthly #4 | Reloading chart. | 2016-04-22 12:17:33 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:33 SPY Monthly #11 | Reloading chart. | 2016-04-22 12:17:33 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:33 SPY Monthly #11 | Reloading chart. | 2016-04-22 12:17:33 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:33 SPY Monthly #4 | Reloading chart. | 2016-04-22 12:17:33 IQFeed | Using primary service for historical data for SPY | 2016-04-22 12:17:33 HD Request # 5 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2016-04-22 12:17:36 HD Request # 5 | Download start Date-Time: 2016-04-22 11:53:32.000 | 2016-04-22 12:17:36 HD Request # 5 | Requesting Tick data beginning at 2016-04-22 11:53:32 US Eastern Time. | 2016-04-22 12:17:36 HD Request # 5 | Receiving historical Intraday Tick data for VXX | 2016-04-22 12:17:36 HD Request # 5 | Receiving Intraday data for VXX starting at 2016-04-22 11:53:32 | 2016-04-22 12:17:36 HD Request # 5 | Timestamp of first Intraday data file record written: 2016-04-22 11:53:32 | 2016-04-22 12:17:36 HD Request # 5 | Received 3863 records from 2016-04-22 11:53:32 to 2016-04-22 12:02:12 (8.7 minutes) and wrote 3863 records for VXX | 2016-04-22 12:17:36 Added 5 Time and Sales records to Intraday data file for VXX after download. | 2016-04-22 12:17:36 HD Request # 5 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 4 | 2016-04-22 12:17:36 Removed historical data download ID 4 | 2016-04-22 12:17:36 Real-time Intraday chart data file updates started for VXX | 2016-04-22 12:17:36 Opened cached Intraday file: C:\SierraChart\Data\VXX.scid | 2016-04-22 12:17:36 Intraday chart data file opened for VXX | 2016-04-22 12:17:36 HD Request # 6 | Downloading Intraday chart data for CORN to the file CORN.scid. Service: dtn | 2016-04-22 12:17:36 HD Request # 6 | Download start Date-Time: 2016-04-22 11:47:22.000 | 2016-04-22 12:17:36 HD Request # 6 | Requesting Tick data beginning at 2016-04-22 11:47:22 US Eastern Time. | 2016-04-22 12:17:36 HD Request # 6 | Receiving historical Intraday Tick data for CORN | 2016-04-22 12:17:37 HD Request # 6 | Receiving Intraday data for CORN starting at 2016-04-22 11:47:22 | 2016-04-22 12:17:37 HD Request # 6 | Timestamp of first Intraday data file record written: 2016-04-22 11:47:22 | 2016-04-22 12:17:37 HD Request # 6 | Received 2 records from 2016-04-22 11:47:22 to 2016-04-22 11:54:01 (6.6 minutes) and wrote 2 records for CORN | 2016-04-22 12:17:37 HD Request # 6 | Intraday download COMPLETE for CORN. Completion time: 0s. Unique request ID: 5 | 2016-04-22 12:17:37 Removed historical data download ID 5 | 2016-04-22 12:17:37 Real-time Intraday chart data file updates started for CORN | 2016-04-22 12:17:37 Opened cached Intraday file: C:\SierraChart\Data\CORN.scid | 2016-04-22 12:17:37 Intraday chart data file opened for CORN | 2016-04-22 12:17:37 HD Request # 7 | Downloading Intraday chart data for SGG to the file SGG.scid. Service: dtn | 2016-04-22 12:17:37 HD Request # 7 | Download start Date-Time: 2016-04-22 11:40:47.000 | 2016-04-22 12:17:37 HD Request # 7 | Requesting Tick data beginning at 2016-04-22 11:40:47 US Eastern Time. | 2016-04-22 12:17:37 HD Request # 7 | Receiving historical Intraday Tick data for SGG | 2016-04-22 12:17:37 HD Request # 7 | Receiving Intraday data for SGG starting at 2016-04-22 11:40:47 | 2016-04-22 12:17:37 HD Request # 7 | Timestamp of first Intraday data file record written: 2016-04-22 11:40:47 | 2016-04-22 12:17:37 HD Request # 7 | Received 1 record from 2016-04-22 11:40:47 to 2016-04-22 11:40:47 (0.0 seconds) and wrote 1 record for SGG | 2016-04-22 12:17:37 HD Request # 7 | Intraday download COMPLETE for SGG. Completion time: 0s. Unique request ID: 6 | 2016-04-22 12:17:37 Removed historical data download ID 6 | 2016-04-22 12:17:37 Real-time Intraday chart data file updates started for SGG | 2016-04-22 12:17:37 Opened cached Intraday file: C:\SierraChart\Data\SGG.scid | 2016-04-22 12:17:37 Intraday chart data file opened for SGG | 2016-04-22 12:17:37 HD Request # 8 | Downloading Intraday chart data for JO to the file JO.scid. Service: dtn | 2016-04-22 12:17:37 HD Request # 8 | Download start Date-Time: 2016-04-22 11:47:13.000 | 2016-04-22 12:17:37 HD Request # 8 | Requesting Tick data beginning at 2016-04-22 11:47:13 US Eastern Time. | 2016-04-22 12:17:37 HD Request # 8 | Receiving historical Intraday Tick data for JO | 2016-04-22 12:17:37 HD Request # 8 | Receiving Intraday data for JO starting at 2016-04-22 11:47:13 | 2016-04-22 12:17:37 HD Request # 8 | Timestamp of first Intraday data file record written: 2016-04-22 11:47:13 | 2016-04-22 12:17:37 HD Request # 8 | Received 11 records from 2016-04-22 11:47:13 to 2016-04-22 12:01:09 (13.9 minutes) and wrote 11 records for JO | 2016-04-22 12:17:37 HD Request # 8 | Intraday download COMPLETE for JO. Completion time: 0s. Unique request ID: 7 | 2016-04-22 12:17:37 Removed historical data download ID 7 | 2016-04-22 12:17:37 Real-time Intraday chart data file updates started for JO | 2016-04-22 12:17:37 Opened cached Intraday file: C:\SierraChart\Data\JO.scid | 2016-04-22 12:17:37 Intraday chart data file opened for JO | 2016-04-22 12:17:37 HD Request # 9 | Downloading Intraday chart data for FXC to the file FXC.scid. Service: dtn | 2016-04-22 12:17:37 HD Request # 9 | Download start Date-Time: 2016-04-22 11:28:48.000 | 2016-04-22 12:17:37 HD Request # 9 | Requesting Tick data beginning at 2016-04-22 11:28:48 US Eastern Time. | 2016-04-22 12:17:37 HD Request # 9 | Receiving historical Intraday Tick data for FXC | 2016-04-22 12:17:37 HD Request # 9 | Receiving Intraday data for FXC starting at 2016-04-22 11:28:48 | 2016-04-22 12:17:37 HD Request # 9 | Timestamp of first Intraday data file record written: 2016-04-22 11:28:48 | 2016-04-22 12:17:37 HD Request # 9 | Received 1 record from 2016-04-22 11:28:48 to 2016-04-22 11:28:48 (0.0 seconds) and wrote 1 record for FXC | 2016-04-22 12:17:37 HD Request # 9 | Intraday download COMPLETE for FXC. Completion time: 0s. Unique request ID: 8 | 2016-04-22 12:17:37 Removed historical data download ID 8 | 2016-04-22 12:17:37 Real-time Intraday chart data file updates started for FXC | 2016-04-22 12:17:37 Opened cached Intraday file: C:\SierraChart\Data\FXC.scid | 2016-04-22 12:17:37 Intraday chart data file opened for FXC | 2016-04-22 12:17:37 HD Request # 10 | Downloading Intraday chart data for MSFT to the file MSFT.scid. Service: dtn | 2016-04-22 12:17:37 HD Request # 10 | Download start Date-Time: 2016-04-22 11:53:34.000 | 2016-04-22 12:17:37 HD Request # 10 | Requesting Tick data beginning at 2016-04-22 11:53:34 US Eastern Time. | 2016-04-22 12:17:37 HD Request # 10 | Receiving historical Intraday Tick data for MSFT | 2016-04-22 12:17:38 HD Request # 10 | Receiving Intraday data for MSFT starting at 2016-04-22 11:53:34 | 2016-04-22 12:17:38 HD Request # 10 | Timestamp of first Intraday data file record written: 2016-04-22 11:53:34 | 2016-04-22 12:17:38 HD Request # 10 | Received 7385 records from 2016-04-22 11:53:34 to 2016-04-22 12:02:16 (8.7 minutes) and wrote 7385 records for MSFT | 2016-04-22 12:17:38 HD Request # 10 | Intraday download COMPLETE for MSFT. Completion time: 0s. Unique request ID: 9 | 2016-04-22 12:17:38 Removed historical data download ID 9 | 2016-04-22 12:17:38 Real-time Intraday chart data file updates started for MSFT | 2016-04-22 12:17:38 Opened cached Intraday file: C:\SierraChart\Data\MSFT.scid | 2016-04-22 12:17:38 Intraday chart data file opened for MSFT | 2016-04-22 12:17:38 HD Request # 11 | Downloading Intraday chart data for HRL to the file HRL.scid. Service: dtn | 2016-04-22 12:17:38 HD Request # 11 | Download start Date-Time: 2016-04-22 11:53:24.000 | 2016-04-22 12:17:38 HD Request # 11 | Requesting Tick data beginning at 2016-04-22 11:53:24 US Eastern Time. | 2016-04-22 12:17:38 HD Request # 11 | Receiving historical Intraday Tick data for HRL | 2016-04-22 12:17:38 HD Request # 11 | Receiving Intraday data for HRL starting at 2016-04-22 11:53:24 | 2016-04-22 12:17:38 HD Request # 11 | Timestamp of first Intraday data file record written: 2016-04-22 11:53:24 | 2016-04-22 12:17:38 HD Request # 11 | Received 195 records from 2016-04-22 11:53:24 to 2016-04-22 12:02:07 (8.7 minutes) and wrote 195 records for HRL | 2016-04-22 12:17:38 HD Request # 11 | Intraday download COMPLETE for HRL. Completion time: 1s. Unique request ID: 10 | 2016-04-22 12:17:38 Removed historical data download ID 10 | 2016-04-22 12:17:38 Real-time Intraday chart data file updates started for HRL | 2016-04-22 12:17:38 Opened cached Intraday file: C:\SierraChart\Data\HRL.scid | 2016-04-22 12:17:38 Intraday chart data file opened for HRL | 2016-04-22 12:17:38 Notice: Detected that the system has resumed from a low-power state. | 2016-04-22 15:56:35 Re-connecting to the Data/Trading service. | 2016-04-22 15:56:35 Socket (9) | Shutdown and closed. | 2016-04-22 15:56:35 IQFeed | Disconnected from Level 2 port. | 2016-04-22 15:56:35 Socket (8) | Shutdown and closed. | 2016-04-22 15:56:35 IQFeed | Disconnected from Lookup port. | 2016-04-22 15:56:35 Socket (7) | Shutdown and closed. | 2016-04-22 15:56:35 IQFeed | Disconnected from Level 1 port. | 2016-04-22 15:56:35 Socket (6) | Shutdown and closed. | 2016-04-22 15:56:35 IQFeed | Disconnected from Admin port. | 2016-04-22 15:56:35 IQFeed | Disconnected. | 2016-04-22 15:56:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 15:56:35 IQFeed | Connecting. | 2016-04-22 15:56:40 IQFeed | Connecting to Admin port 9300 | 2016-04-22 15:56:40 Socket (121) | Connected. | 2016-04-22 15:56:43 IQFeed | Connected to Admin port. | 2016-04-22 15:56:43 Socket (121) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-04-22 15:56:43 Socket (121) | Shutdown and closed. | 2016-04-22 15:56:43 IQFeed | Disconnected from Admin port. | 2016-04-22 15:56:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-22 15:56:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-22 15:56:43 IQFeed | Disconnected. | 2016-04-22 15:56:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 15:56:43 IQFeed | Connecting. | 2016-04-22 15:56:46 IQFeed | Connecting to Admin port 9300 | 2016-04-22 15:56:46 Socket (122) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-04-22 15:56:47 Socket (122) | Shutdown and closed. | 2016-04-22 15:56:47 IQFeed | Disconnected from Admin port. | 2016-04-22 15:56:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-22 15:56:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-22 15:56:47 Starting DTN IQ Feed interface software. | 2016-04-22 15:56:47 IQFeed | Disconnected. | 2016-04-22 15:56:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 15:56:47 IQFeed | Connecting. | 2016-04-22 15:56:50 IQFeed | Connecting to Admin port 9300 | 2016-04-22 15:56:50 Socket (123) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-04-22 15:56:52 Socket (123) | Shutdown and closed. | 2016-04-22 15:56:52 IQFeed | Disconnected from Admin port. | 2016-04-22 15:56:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-22 15:56:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-22 15:56:52 Starting DTN IQ Feed interface software. | 2016-04-22 15:56:52 IQFeed | Disconnected. | 2016-04-22 15:56:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 15:56:52 IQFeed | Connecting. | 2016-04-22 15:56:55 IQFeed | Connecting to Admin port 9300 | 2016-04-22 15:56:55 Socket (124) | Connected. | 2016-04-22 15:56:55 IQFeed | Connected to Admin port. | 2016-04-22 15:56:55 AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2016-04-22 15:56:55 AdminMessage: S,STATS,66.112.148.224,60005,500,0,1,0,0,0,Apr 22 3:56PM,,Connected,5.2.0.9,ptrhbg1,0.03,0.03,0,0.03,0.0,0, | 2016-04-22 15:56:55 IQFeed | Connecting to Level 1 port 5009 | 2016-04-22 15:56:55 Socket (125) | Connected. | 2016-04-22 15:56:55 IQFeed | Connected to Level 1 port. | 2016-04-22 15:56:55 IQFeed | Connecting to Lookup port 9100 | 2016-04-22 15:56:55 IQFeed | Connecting to Level 2 port (9200)... | 2016-04-22 15:56:55 Socket (126) | Connected. | 2016-04-22 15:56:55 IQFeed | Connected to Historical Data port. | 2016-04-22 15:56:55 IQFeed | Connected to data server. | 2016-04-22 15:56:55 Socket (127) | Connected. | 2016-04-22 15:56:55 IQFeed | Connected to Level 2 port. | 2016-04-22 15:56:55 IQFeed Level 2 error: Account not authorized for Level II | 2016-04-22 15:56:55 IQFeed | Level 1 system message: KEY | 2016-04-22 15:56:55 IQFeed | Level 1 system message: SERVER CONNECTED | 2016-04-22 15:56:55 IQFeed | Level 1 system message: IP | 2016-04-22 15:56:55 IQFeed | Level 1 system message: CUST | 2016-04-22 15:56:55 IQFeed | Level 2 protocol is 5.0. | 2016-04-22 15:56:55 IQFeed | Starting real-time market data updates for: @ES#. ID: 1 | 2016-04-22 15:56:55 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 15:56:55 Intraday data recording state for symbol @ES# is set to download 'Pending'. | 2016-04-22 15:56:55 Delaying start of download for @ES# | 2016-04-22 15:56:55 IQFeed | Starting real-time market data updates for: VXX. ID: 2 | 2016-04-22 15:56:55 IQFeed | Using primary service for historical data for VXX | 2016-04-22 15:56:55 Intraday data recording state for symbol VXX is set to download 'Pending'. | 2016-04-22 15:56:55 IQFeed | Starting real-time market data updates for: SPY. ID: 3 | 2016-04-22 15:56:55 IQFeed | Starting real-time market data updates for: CORN. ID: 4 | 2016-04-22 15:56:55 IQFeed | Using primary service for historical data for CORN | 2016-04-22 15:56:55 Intraday data recording state for symbol CORN is set to download 'Pending'. | 2016-04-22 15:56:55 IQFeed | Starting real-time market data updates for: SGG. ID: 5 | 2016-04-22 15:56:55 IQFeed | Using primary service for historical data for SGG | 2016-04-22 15:56:55 Intraday data recording state for symbol SGG is set to download 'Pending'. | 2016-04-22 15:56:55 IQFeed | Starting real-time market data updates for: JO. ID: 6 | 2016-04-22 15:56:55 IQFeed | Using primary service for historical data for JO | 2016-04-22 15:56:55 Intraday data recording state for symbol JO is set to download 'Pending'. | 2016-04-22 15:56:55 IQFeed | Starting real-time market data updates for: FXC. ID: 7 | 2016-04-22 15:56:55 IQFeed | Using primary service for historical data for FXC | 2016-04-22 15:56:55 Intraday data recording state for symbol FXC is set to download 'Pending'. | 2016-04-22 15:56:55 IQFeed | Starting real-time market data updates for: MSFT. ID: 8 | 2016-04-22 15:56:55 IQFeed | Using primary service for historical data for MSFT | 2016-04-22 15:56:55 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2016-04-22 15:56:55 IQFeed | Starting real-time market data updates for: HRL. ID: 9 | 2016-04-22 15:56:55 IQFeed | Using primary service for historical data for HRL | 2016-04-22 15:56:55 Intraday data recording state for symbol HRL is set to download 'Pending'. | 2016-04-22 15:56:55 @ES# Weekly #2 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 15:56:56 @ES# Monthly #1 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 15:56:56 @ES# Monthly #1 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 15:56:56 @ES# Weekly #2 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 15:56:56 @ES# Monthly #1 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 15:56:56 SPY Monthly #11 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for SPY | 2016-04-22 15:56:56 SPY Monthly #11 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for SPY | 2016-04-22 15:56:56 SPY Monthly #4 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for SPY | 2016-04-22 15:56:56 SPY Monthly #4 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for SPY | 2016-04-22 15:56:56 SPY Monthly #11 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for SPY | 2016-04-22 15:56:56 SPY Monthly #4 | Reloading chart. | 2016-04-22 15:56:56 IQFeed | Using primary service for historical data for SPY | 2016-04-22 15:56:56 Delaying start of download for @ES# | 2016-04-22 15:56:56 HD Request # 12 | Downloading Intraday chart data for @ES# to the file @ES#.scid. Service: dtn | 2016-04-22 15:57:00 HD Request # 12 | Download start Date-Time: 2016-04-22 15:56:04.000 | 2016-04-22 15:57:00 HD Request # 12 | Requesting Tick data beginning at 2016-04-22 15:56:04 US Eastern Time. | 2016-04-22 15:57:00 HD Request # 12 | Receiving historical Intraday Tick data for @ES# | 2016-04-22 15:57:00 HD Request # 12 | Receiving Intraday data for @ES# starting at 2016-04-22 15:56:04 | 2016-04-22 15:57:00 HD Request # 12 | Timestamp of first Intraday data file record written: 2016-04-22 15:56:04 | 2016-04-22 15:57:00 HD Request # 12 | Received 499 records from 2016-04-22 15:56:04 to 2016-04-22 15:56:37 (33.0 seconds) and wrote 499 records for @ES# | 2016-04-22 15:57:00 Added 2 Time and Sales records to Intraday data file for @ES# after download. | 2016-04-22 15:57:00 HD Request # 12 | Intraday download COMPLETE for @ES#. Completion time: 1s. Unique request ID: 11 | 2016-04-22 15:57:00 Removed historical data download ID 11 | 2016-04-22 15:57:00 Real-time Intraday chart data file updates started for @ES# | 2016-04-22 15:57:00 Opened cached Intraday file: C:\SierraChart\Data\@ES#.scid | 2016-04-22 15:57:00 Intraday chart data file opened for @ES# | 2016-04-22 15:57:00 HD Request # 13 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2016-04-22 15:57:00 HD Request # 13 | Download start Date-Time: 2016-04-22 15:41:03.000 | 2016-04-22 15:57:00 HD Request # 13 | Requesting Tick data beginning at 2016-04-22 15:41:03 US Eastern Time. | 2016-04-22 15:57:00 HD Request # 13 | Receiving historical Intraday Tick data for VXX | 2016-04-22 15:57:00 HD Request # 13 | Receiving Intraday data for VXX starting at 2016-04-22 15:41:03 | 2016-04-22 15:57:00 HD Request # 13 | Timestamp of first Intraday data file record written: 2016-04-22 15:41:03 | 2016-04-22 15:57:00 HD Request # 13 | Received 198 records from 2016-04-22 15:41:03 to 2016-04-22 15:41:39 (36.0 seconds) and wrote 198 records for VXX | 2016-04-22 15:57:00 HD Request # 13 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 12 | 2016-04-22 15:57:00 Removed historical data download ID 12 | 2016-04-22 15:57:00 Real-time Intraday chart data file updates started for VXX | 2016-04-22 15:57:00 Opened cached Intraday file: C:\SierraChart\Data\VXX.scid | 2016-04-22 15:57:00 Intraday chart data file opened for VXX | 2016-04-22 15:57:00 HD Request # 14 | Downloading Intraday chart data for CORN to the file CORN.scid. Service: dtn | 2016-04-22 15:57:00 HD Request # 14 | Download start Date-Time: 2016-04-22 15:40:44.000 | 2016-04-22 15:57:00 HD Request # 14 | Requesting Tick data beginning at 2016-04-22 15:40:44 US Eastern Time. | 2016-04-22 15:57:00 HD Request # 14 | Receiving historical Intraday Tick data for CORN | 2016-04-22 15:57:00 HD Request # 14 | Receiving Intraday data for CORN starting at 2016-04-22 15:40:44 | 2016-04-22 15:57:00 HD Request # 14 | Timestamp of first Intraday data file record written: 2016-04-22 15:40:44 | 2016-04-22 15:57:00 HD Request # 14 | Received 1 record from 2016-04-22 15:40:44 to 2016-04-22 15:40:44 (0.0 seconds) and wrote 1 record for CORN | 2016-04-22 15:57:00 HD Request # 14 | Intraday download COMPLETE for CORN. Completion time: 0s. Unique request ID: 13 | 2016-04-22 15:57:00 Removed historical data download ID 13 | 2016-04-22 15:57:00 Real-time Intraday chart data file updates started for CORN | 2016-04-22 15:57:00 Opened cached Intraday file: C:\SierraChart\Data\CORN.scid | 2016-04-22 15:57:00 Intraday chart data file opened for CORN | 2016-04-22 15:57:00 HD Request # 15 | Downloading Intraday chart data for SGG to the file SGG.scid. Service: dtn | 2016-04-22 15:57:00 HD Request # 15 | Download start Date-Time: 2016-04-22 15:37:49.000 | 2016-04-22 15:57:00 HD Request # 15 | Requesting Tick data beginning at 2016-04-22 15:37:49 US Eastern Time. | 2016-04-22 15:57:00 HD Request # 15 | Receiving historical Intraday Tick data for SGG | 2016-04-22 15:57:00 HD Request # 15 | Receiving Intraday data for SGG starting at 2016-04-22 15:37:49 | 2016-04-22 15:57:00 HD Request # 15 | Timestamp of first Intraday data file record written: 2016-04-22 15:37:49 | 2016-04-22 15:57:00 HD Request # 15 | Received 1 record from 2016-04-22 15:37:49 to 2016-04-22 15:37:49 (0.0 seconds) and wrote 1 record for SGG | 2016-04-22 15:57:00 Added 1 Time and Sales records to Intraday data file for SGG after download. | 2016-04-22 15:57:00 HD Request # 15 | Intraday download COMPLETE for SGG. Completion time: 0s. Unique request ID: 14 | 2016-04-22 15:57:00 Removed historical data download ID 14 | 2016-04-22 15:57:00 Real-time Intraday chart data file updates started for SGG | 2016-04-22 15:57:00 Opened cached Intraday file: C:\SierraChart\Data\SGG.scid | 2016-04-22 15:57:00 Intraday chart data file opened for SGG | 2016-04-22 15:57:00 Delaying start of download for JO | 2016-04-22 15:57:00 HD Request # 16 | Downloading Intraday chart data for JO to the file JO.scid. Service: dtn | 2016-04-22 15:57:00 HD Request # 16 | Download start Date-Time: 2016-04-22 15:40:38.000 | 2016-04-22 15:57:00 HD Request # 16 | Requesting Tick data beginning at 2016-04-22 15:40:38 US Eastern Time. | 2016-04-22 15:57:00 HD Request # 16 | Receiving historical Intraday Tick data for JO | 2016-04-22 15:57:00 HD Request # 16 | Receiving Intraday data for JO starting at 2016-04-22 15:40:38 | 2016-04-22 15:57:00 HD Request # 16 | Timestamp of first Intraday data file record written: 2016-04-22 15:40:38 | 2016-04-22 15:57:00 HD Request # 16 | Received 1 record from 2016-04-22 15:40:38 to 2016-04-22 15:40:38 (0.0 seconds) and wrote 1 record for JO | 2016-04-22 15:57:00 HD Request # 16 | Intraday download COMPLETE for JO. Completion time: 0s. Unique request ID: 15 | 2016-04-22 15:57:00 Removed historical data download ID 15 | 2016-04-22 15:57:00 Real-time Intraday chart data file updates started for JO | 2016-04-22 15:57:00 Opened cached Intraday file: C:\SierraChart\Data\JO.scid | 2016-04-22 15:57:00 Intraday chart data file opened for JO | 2016-04-22 15:57:00 Delaying start of download for FXC | 2016-04-22 15:57:00 HD Request # 17 | Downloading Intraday chart data for FXC to the file FXC.scid. Service: dtn | 2016-04-22 15:57:01 HD Request # 17 | Download start Date-Time: 2016-04-22 15:33:06.000 | 2016-04-22 15:57:01 HD Request # 17 | Requesting Tick data beginning at 2016-04-22 15:33:06 US Eastern Time. | 2016-04-22 15:57:01 HD Request # 17 | Receiving historical Intraday Tick data for FXC | 2016-04-22 15:57:01 HD Request # 17 | Receiving Intraday data for FXC starting at 2016-04-22 15:33:06 | 2016-04-22 15:57:01 HD Request # 17 | Timestamp of first Intraday data file record written: 2016-04-22 15:33:06 | 2016-04-22 15:57:01 HD Request # 17 | Received 1 record from 2016-04-22 15:33:06 to 2016-04-22 15:33:06 (0.0 seconds) and wrote 1 record for FXC | 2016-04-22 15:57:01 Added 1 Time and Sales records to Intraday data file for FXC after download. | 2016-04-22 15:57:01 HD Request # 17 | Intraday download COMPLETE for FXC. Completion time: 0s. Unique request ID: 16 | 2016-04-22 15:57:01 Removed historical data download ID 16 | 2016-04-22 15:57:01 Real-time Intraday chart data file updates started for FXC | 2016-04-22 15:57:01 Opened cached Intraday file: C:\SierraChart\Data\FXC.scid | 2016-04-22 15:57:01 Intraday chart data file opened for FXC | 2016-04-22 15:57:01 HD Request # 18 | Downloading Intraday chart data for MSFT to the file MSFT.scid. Service: dtn | 2016-04-22 15:57:01 HD Request # 18 | Download start Date-Time: 2016-04-22 15:41:03.000 | 2016-04-22 15:57:01 HD Request # 18 | Requesting Tick data beginning at 2016-04-22 15:41:03 US Eastern Time. | 2016-04-22 15:57:01 HD Request # 18 | Receiving historical Intraday Tick data for MSFT | 2016-04-22 15:57:01 HD Request # 18 | Receiving Intraday data for MSFT starting at 2016-04-22 15:41:03 | 2016-04-22 15:57:01 HD Request # 18 | Timestamp of first Intraday data file record written: 2016-04-22 15:41:03 | 2016-04-22 15:57:01 HD Request # 18 | Received 1129 records from 2016-04-22 15:41:03 to 2016-04-22 15:41:39 (36.0 seconds) and wrote 1129 records for MSFT | 2016-04-22 15:57:01 Added 4 Time and Sales records to Intraday data file for MSFT after download. | 2016-04-22 15:57:01 HD Request # 18 | Intraday download COMPLETE for MSFT. Completion time: 0s. Unique request ID: 17 | 2016-04-22 15:57:01 Removed historical data download ID 17 | 2016-04-22 15:57:01 Real-time Intraday chart data file updates started for MSFT | 2016-04-22 15:57:01 Opened cached Intraday file: C:\SierraChart\Data\MSFT.scid | 2016-04-22 15:57:01 Intraday chart data file opened for MSFT | 2016-04-22 15:57:01 HD Request # 19 | Downloading Intraday chart data for HRL to the file HRL.scid. Service: dtn | 2016-04-22 15:57:01 HD Request # 19 | Download start Date-Time: 2016-04-22 15:41:02.000 | 2016-04-22 15:57:01 HD Request # 19 | Requesting Tick data beginning at 2016-04-22 15:41:02 US Eastern Time. | 2016-04-22 15:57:01 HD Request # 19 | Receiving historical Intraday Tick data for HRL | 2016-04-22 15:57:01 HD Request # 19 | Receiving Intraday data for HRL starting at 2016-04-22 15:41:02 | 2016-04-22 15:57:01 HD Request # 19 | Timestamp of first Intraday data file record written: 2016-04-22 15:41:02 | 2016-04-22 15:57:01 HD Request # 19 | Received 8 records from 2016-04-22 15:41:02 to 2016-04-22 15:41:40 (38.0 seconds) and wrote 8 records for HRL | 2016-04-22 15:57:01 HD Request # 19 | Intraday download COMPLETE for HRL. Completion time: 0s. Unique request ID: 18 | 2016-04-22 15:57:01 Removed historical data download ID 18 | 2016-04-22 15:57:01 Real-time Intraday chart data file updates started for HRL | 2016-04-22 15:57:01 Opened cached Intraday file: C:\SierraChart\Data\HRL.scid | 2016-04-22 15:57:01 Intraday chart data file opened for HRL | 2016-04-22 15:57:01 IQFeed | Level 2 port reports server is disconnected. | 2016-04-22 18:50:22 IQFeed | Level 1 system message: SERVER DISCONNECTED | 2016-04-22 18:50:22 IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2016-04-22 18:50:22 Connection to the external service has been lost. | 2016-04-22 18:50:22 Socket (127) | Shutdown and closed. | 2016-04-22 18:50:22 IQFeed | Disconnected from Level 2 port. | 2016-04-22 18:50:22 Socket (126) | Shutdown and closed. | 2016-04-22 18:50:22 IQFeed | Disconnected from Lookup port. | 2016-04-22 18:50:22 Socket (125) | Shutdown and closed. | 2016-04-22 18:50:22 IQFeed | Disconnected from Level 1 port. | 2016-04-22 18:50:22 Socket (124) | Shutdown and closed. | 2016-04-22 18:50:22 IQFeed | Disconnected from Admin port. | 2016-04-22 18:50:22 IQFeed | Disconnected. | 2016-04-22 18:50:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 18:50:22 IQFeed | Connecting. | 2016-04-22 18:50:25 IQFeed | Connecting to Admin port 9300 | 2016-04-22 18:50:25 Socket (217) | Connected. | 2016-04-22 18:50:28 IQFeed | Connected to Admin port. | 2016-04-22 18:50:28 Socket (217) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-04-22 18:50:28 Socket (217) | Shutdown and closed. | 2016-04-22 18:50:28 IQFeed | Disconnected from Admin port. | 2016-04-22 18:50:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-22 18:50:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-22 18:50:28 IQFeed | Disconnected. | 2016-04-22 18:50:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 18:50:28 IQFeed | Connecting. | 2016-04-22 18:50:31 IQFeed | Connecting to Admin port 9300 | 2016-04-22 18:50:31 Socket (218) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-04-22 18:50:32 Socket (218) | Shutdown and closed. | 2016-04-22 18:50:32 IQFeed | Disconnected from Admin port. | 2016-04-22 18:50:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-22 18:50:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-22 18:50:32 Starting DTN IQ Feed interface software. | 2016-04-22 18:50:32 IQFeed | Disconnected. | 2016-04-22 18:50:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 18:50:32 IQFeed | Connecting. | 2016-04-22 18:50:35 IQFeed | Connecting to Admin port 9300 | 2016-04-22 18:50:35 Socket (219) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-04-22 18:50:36 Socket (219) | Shutdown and closed. | 2016-04-22 18:50:36 IQFeed | Disconnected from Admin port. | 2016-04-22 18:50:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-22 18:50:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-22 18:50:36 Starting DTN IQ Feed interface software. | 2016-04-22 18:50:36 IQFeed | Disconnected. | 2016-04-22 18:50:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 18:50:36 IQFeed | Connecting. | 2016-04-22 18:50:39 IQFeed | Connecting to Admin port 9300 | 2016-04-22 18:50:39 Socket (220) | Connected. | 2016-04-22 18:50:39 IQFeed | Connected to Admin port. | 2016-04-22 18:50:39 AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2016-04-22 18:50:39 AdminMessage: S,STATS,66.112.148.225,60005,500,0,1,0,0,0,Apr 22 6:50PM,Apr 22 06:50PM,Connected,5.2.0.9,ptrhbg1,0.06,0.02,0.06,0.03,0.0,0.03, | 2016-04-22 18:50:40 IQFeed | Connecting to Level 1 port 5009 | 2016-04-22 18:50:40 Socket (221) | Connected. | 2016-04-22 18:50:40 IQFeed | Connected to Level 1 port. | 2016-04-22 18:50:40 IQFeed | Connecting to Lookup port 9100 | 2016-04-22 18:50:40 IQFeed | Connecting to Level 2 port (9200)... | 2016-04-22 18:50:40 Socket (222) | Connected. | 2016-04-22 18:50:40 IQFeed | Connected to Historical Data port. | 2016-04-22 18:50:40 IQFeed | Connected to data server. | 2016-04-22 18:50:40 Socket (223) | Connected. | 2016-04-22 18:50:40 IQFeed | Connected to Level 2 port. | 2016-04-22 18:50:40 IQFeed Level 2 error: Account not authorized for Level II | 2016-04-22 18:50:40 IQFeed | Starting real-time market data updates for: @ES#. ID: 1 | 2016-04-22 18:50:40 IQFeed | Level 1 system message: KEY | 2016-04-22 18:50:40 IQFeed | Level 1 system message: SERVER CONNECTED | 2016-04-22 18:50:40 IQFeed | Level 1 system message: IP | 2016-04-22 18:50:40 IQFeed | Level 1 system message: CUST | 2016-04-22 18:50:40 IQFeed | Level 2 protocol is 5.0. | 2016-04-22 18:50:40 IQFeed | Starting real-time market data updates for: SPY. ID: 2 | 2016-04-22 18:50:40 IQFeed | Starting real-time market data updates for: MSFT. ID: 3 | 2016-04-22 18:50:40 IQFeed | Using primary service for historical data for MSFT | 2016-04-22 18:50:40 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2016-04-22 18:50:40 Delaying start of download for MSFT | 2016-04-22 18:50:40 IQFeed | Starting real-time market data updates for: HRL. ID: 4 | 2016-04-22 18:50:40 IQFeed | Using primary service for historical data for HRL | 2016-04-22 18:50:40 Intraday data recording state for symbol HRL is set to download 'Pending'. | 2016-04-22 18:50:40 IQFeed | Using primary service for historical data for @ES# | 2016-04-22 18:50:40 Intraday data recording state for symbol @ES# is set to download 'Pending'. | 2016-04-22 18:50:40 IQFeed | Starting real-time market data updates for: VXX. ID: 5 | 2016-04-22 18:50:40 IQFeed | Using primary service for historical data for VXX | 2016-04-22 18:50:40 Intraday data recording state for symbol VXX is set to download 'Pending'. | 2016-04-22 18:50:40 IQFeed | Starting real-time market data updates for: CORN. ID: 6 | 2016-04-22 18:50:40 IQFeed | Using primary service for historical data for CORN | 2016-04-22 18:50:40 Intraday data recording state for symbol CORN is set to download 'Pending'. | 2016-04-22 18:50:40 IQFeed | Starting real-time market data updates for: SGG. ID: 7 | 2016-04-22 18:50:40 IQFeed | Using primary service for historical data for SGG | 2016-04-22 18:50:40 Intraday data recording state for symbol SGG is set to download 'Pending'. | 2016-04-22 18:50:40 IQFeed | Starting real-time market data updates for: JO. ID: 8 | 2016-04-22 18:50:40 IQFeed | Using primary service for historical data for JO | 2016-04-22 18:50:40 Intraday data recording state for symbol JO is set to download 'Pending'. | 2016-04-22 18:50:40 IQFeed | Starting real-time market data updates for: FXC. ID: 9 | 2016-04-22 18:50:40 IQFeed | Using primary service for historical data for FXC | 2016-04-22 18:50:40 Intraday data recording state for symbol FXC is set to download 'Pending'. | 2016-04-22 18:50:40 Delaying start of download for MSFT | 2016-04-22 18:50:40 HD Request # 20 | Downloading Intraday chart data for MSFT to the file MSFT.scid. Service: dtn | 2016-04-22 18:50:45 HD Request # 20 | Download start Date-Time: 2016-04-22 18:32:40.000 | 2016-04-22 18:50:45 HD Request # 20 | Requesting Tick data beginning at 2016-04-22 18:32:40 US Eastern Time. | 2016-04-22 18:50:45 HD Request # 20 | Receiving historical Intraday Tick data for MSFT | 2016-04-22 18:50:45 HD Request # 20 | Receiving Intraday data for MSFT starting at 2016-04-22 18:32:40 | 2016-04-22 18:50:45 HD Request # 20 | Timestamp of first Intraday data file record written: 2016-04-22 18:32:40 | 2016-04-22 18:50:45 HD Request # 20 | Received 1 record from 2016-04-22 18:32:40 to 2016-04-22 18:32:40 (0.0 seconds) and wrote 1 record for MSFT | 2016-04-22 18:50:45 HD Request # 20 | Intraday download COMPLETE for MSFT. Completion time: 0s. Unique request ID: 19 | 2016-04-22 18:50:45 Removed historical data download ID 19 | 2016-04-22 18:50:45 Real-time Intraday chart data file updates started for MSFT | 2016-04-22 18:50:45 Opened cached Intraday file: C:\SierraChart\Data\MSFT.scid | 2016-04-22 18:50:45 Intraday chart data file opened for MSFT | 2016-04-22 18:50:45 Delaying start of download for HRL | 2016-04-22 18:50:45 HD Request # 21 | Downloading Intraday chart data for HRL to the file HRL.scid. Service: dtn | 2016-04-22 18:50:45 HD Request # 21 | Download start Date-Time: 2016-04-22 16:07:48.000 | 2016-04-22 18:50:45 HD Request # 21 | Requesting Tick data beginning at 2016-04-22 16:07:48 US Eastern Time. | 2016-04-22 18:50:45 HD Request # 21 | Receiving historical Intraday Tick data for HRL | 2016-04-22 18:50:45 HD Request # 21 | Receiving Intraday data for HRL starting at 2016-04-22 16:07:48 | 2016-04-22 18:50:45 HD Request # 21 | Timestamp of first Intraday data file record written: 2016-04-22 16:07:48 | 2016-04-22 18:50:45 HD Request # 21 | Received 1 record from 2016-04-22 16:07:48 to 2016-04-22 16:07:48 (0.0 seconds) and wrote 1 record for HRL | 2016-04-22 18:50:45 Added 11 Time and Sales records to Intraday data file for HRL after download. | 2016-04-22 18:50:45 HD Request # 21 | Intraday download COMPLETE for HRL. Completion time: 1s. Unique request ID: 20 | 2016-04-22 18:50:45 Removed historical data download ID 20 | 2016-04-22 18:50:45 Real-time Intraday chart data file updates started for HRL | 2016-04-22 18:50:45 Opened cached Intraday file: C:\SierraChart\Data\HRL.scid | 2016-04-22 18:50:45 Intraday chart data file opened for HRL | 2016-04-22 18:50:45 Delaying start of download for @ES# | 2016-04-22 18:50:45 HD Request # 22 | Downloading Intraday chart data for @ES# to the file @ES#.scid. Service: dtn | 2016-04-22 18:50:45 HD Request # 22 | Download start Date-Time: 2016-04-22 16:59:59.000 | 2016-04-22 18:50:45 HD Request # 22 | Requesting Tick data beginning at 2016-04-22 16:59:59 US Eastern Time. | 2016-04-22 18:50:45 HD Request # 22 | Receiving historical Intraday Tick data for @ES# | 2016-04-22 18:50:45 HD Request # 22 | Receiving Intraday data for @ES# starting at 2016-04-22 16:59:59 | 2016-04-22 18:50:45 HD Request # 22 | Timestamp of first Intraday data file record written: 2016-04-22 16:59:59 | 2016-04-22 18:50:45 HD Request # 22 | Received 5 records from 2016-04-22 16:59:59 to 2016-04-22 16:59:59 (0.0 seconds) and wrote 5 records for @ES# | 2016-04-22 18:50:45 Added 4 Time and Sales records to Intraday data file for @ES# after download. | 2016-04-22 18:50:45 HD Request # 22 | Intraday download COMPLETE for @ES#. Completion time: 0s. Unique request ID: 21 | 2016-04-22 18:50:45 Removed historical data download ID 21 | 2016-04-22 18:50:45 Real-time Intraday chart data file updates started for @ES# | 2016-04-22 18:50:45 Opened cached Intraday file: C:\SierraChart\Data\@ES#.scid | 2016-04-22 18:50:45 Intraday chart data file opened for @ES# | 2016-04-22 18:50:45 HD Request # 23 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2016-04-22 18:50:45 HD Request # 23 | Download start Date-Time: 2016-04-22 18:33:26.000 | 2016-04-22 18:50:45 HD Request # 23 | Requesting Tick data beginning at 2016-04-22 18:33:26 US Eastern Time. | 2016-04-22 18:50:45 HD Request # 23 | Receiving historical Intraday Tick data for VXX | 2016-04-22 18:50:46 HD Request # 23 | Receiving Intraday data for VXX starting at 2016-04-22 18:33:26 | 2016-04-22 18:50:46 HD Request # 23 | Timestamp of first Intraday data file record written: 2016-04-22 18:33:26 | 2016-04-22 18:50:46 HD Request # 23 | Received 3 records from 2016-04-22 18:33:26 to 2016-04-22 18:35:10 (104.0 seconds) and wrote 3 records for VXX | 2016-04-22 18:50:46 HD Request # 23 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 22 | 2016-04-22 18:50:46 Removed historical data download ID 22 | 2016-04-22 18:50:46 Real-time Intraday chart data file updates started for VXX | 2016-04-22 18:50:46 Opened cached Intraday file: C:\SierraChart\Data\VXX.scid | 2016-04-22 18:50:46 Intraday chart data file opened for VXX | 2016-04-22 18:50:46 HD Request # 24 | Downloading Intraday chart data for CORN to the file CORN.scid. Service: dtn | 2016-04-22 18:50:46 HD Request # 24 | Download start Date-Time: 2016-04-22 16:00:00.000 | 2016-04-22 18:50:46 HD Request # 24 | Requesting Tick data beginning at 2016-04-22 16:00:00 US Eastern Time. | 2016-04-22 18:50:46 HD Request # 24 | Receiving historical Intraday Tick data for CORN | 2016-04-22 18:50:46 HD Request # 24 | Receiving Intraday data for CORN starting at 2016-04-22 16:00:00 | 2016-04-22 18:50:46 HD Request # 24 | Timestamp of first Intraday data file record written: 2016-04-22 16:00:00 | 2016-04-22 18:50:46 HD Request # 24 | Received 1 record from 2016-04-22 16:00:00 to 2016-04-22 16:00:00 (0.0 seconds) and wrote 1 record for CORN | 2016-04-22 18:50:46 Added 4 Time and Sales records to Intraday data file for CORN after download. | 2016-04-22 18:50:46 HD Request # 24 | Intraday download COMPLETE for CORN. Completion time: 0s. Unique request ID: 23 | 2016-04-22 18:50:46 Removed historical data download ID 23 | 2016-04-22 18:50:46 Real-time Intraday chart data file updates started for CORN | 2016-04-22 18:50:46 Opened cached Intraday file: C:\SierraChart\Data\CORN.scid | 2016-04-22 18:50:46 Intraday chart data file opened for CORN | 2016-04-22 18:50:46 HD Request # 25 | Downloading Intraday chart data for SGG to the file SGG.scid. Service: dtn | 2016-04-22 18:50:46 HD Request # 25 | Download start Date-Time: 2016-04-22 15:56:37.000 | 2016-04-22 18:50:46 HD Request # 25 | Requesting Tick data beginning at 2016-04-22 15:56:37 US Eastern Time. | 2016-04-22 18:50:46 HD Request # 25 | Receiving historical Intraday Tick data for SGG | 2016-04-22 18:50:46 HD Request # 25 | Receiving Intraday data for SGG starting at 2016-04-22 15:56:37 | 2016-04-22 18:50:46 HD Request # 25 | Timestamp of first Intraday data file record written: 2016-04-22 15:56:37 | 2016-04-22 18:50:46 HD Request # 25 | Received 1 record from 2016-04-22 15:56:37 to 2016-04-22 15:56:37 (0.0 seconds) and wrote 1 record for SGG | 2016-04-22 18:50:46 Added 4 Time and Sales records to Intraday data file for SGG after download. | 2016-04-22 18:50:46 HD Request # 25 | Intraday download COMPLETE for SGG. Completion time: 1s. Unique request ID: 24 | 2016-04-22 18:50:46 Removed historical data download ID 24 | 2016-04-22 18:50:46 Real-time Intraday chart data file updates started for SGG | 2016-04-22 18:50:46 Opened cached Intraday file: C:\SierraChart\Data\SGG.scid | 2016-04-22 18:50:46 Intraday chart data file opened for SGG | 2016-04-22 18:50:46 HD Request # 26 | Downloading Intraday chart data for JO to the file JO.scid. Service: dtn | 2016-04-22 18:50:46 HD Request # 26 | Download start Date-Time: 2016-04-22 16:03:12.000 | 2016-04-22 18:50:46 HD Request # 26 | Requesting Tick data beginning at 2016-04-22 16:03:12 US Eastern Time. | 2016-04-22 18:50:46 HD Request # 26 | Receiving historical Intraday Tick data for JO | 2016-04-22 18:50:46 HD Request # 26 | Receiving Intraday data for JO starting at 2016-04-22 16:03:12 | 2016-04-22 18:50:46 HD Request # 26 | Timestamp of first Intraday data file record written: 2016-04-22 16:03:12 | 2016-04-22 18:50:46 HD Request # 26 | Received 2 records from 2016-04-22 16:03:12 to 2016-04-22 16:03:12 (0.0 seconds) and wrote 2 records for JO | 2016-04-22 18:50:46 Added 5 Time and Sales records to Intraday data file for JO after download. | 2016-04-22 18:50:46 HD Request # 26 | Intraday download COMPLETE for JO. Completion time: 0s. Unique request ID: 25 | 2016-04-22 18:50:46 Removed historical data download ID 25 | 2016-04-22 18:50:46 Real-time Intraday chart data file updates started for JO | 2016-04-22 18:50:46 Opened cached Intraday file: C:\SierraChart\Data\JO.scid | 2016-04-22 18:50:46 Intraday chart data file opened for JO | 2016-04-22 18:50:46 HD Request # 27 | Downloading Intraday chart data for FXC to the file FXC.scid. Service: dtn | 2016-04-22 18:50:46 HD Request # 27 | Download start Date-Time: 2016-04-22 16:00:00.000 | 2016-04-22 18:50:46 HD Request # 27 | Requesting Tick data beginning at 2016-04-22 16:00:00 US Eastern Time. | 2016-04-22 18:50:46 HD Request # 27 | Receiving historical Intraday Tick data for FXC | 2016-04-22 18:50:46 HD Request # 27 | Receiving Intraday data for FXC starting at 2016-04-22 16:00:00 | 2016-04-22 18:50:46 HD Request # 27 | Timestamp of first Intraday data file record written: 2016-04-22 16:00:00 | 2016-04-22 18:50:46 HD Request # 27 | Received 1 record from 2016-04-22 16:00:00 to 2016-04-22 16:00:00 (0.0 seconds) and wrote 1 record for FXC | 2016-04-22 18:50:46 Added 4 Time and Sales records to Intraday data file for FXC after download. | 2016-04-22 18:50:46 HD Request # 27 | Intraday download COMPLETE for FXC. Completion time: 0s. Unique request ID: 26 | 2016-04-22 18:50:46 Removed historical data download ID 26 | 2016-04-22 18:50:46 Real-time Intraday chart data file updates started for FXC | 2016-04-22 18:50:46 Opened cached Intraday file: C:\SierraChart\Data\FXC.scid | 2016-04-22 18:50:46 Intraday chart data file opened for FXC | 2016-04-22 18:50:46 SPY Monthly #4 | Reloading chart. | 2016-04-22 18:51:19 IQFeed | Using primary service for historical data for SPY | 2016-04-22 18:51:19 SPY Monthly #11 | Reloading chart. | 2016-04-22 18:51:19 IQFeed | Using primary service for historical data for SPY | 2016-04-22 18:51:19 SPY Monthly #11 | Reloading chart. | 2016-04-22 18:51:19 IQFeed | Using primary service for historical data for SPY | 2016-04-22 18:51:19 SPY Monthly #4 | Reloading chart. | 2016-04-22 18:51:19 IQFeed | Using primary service for historical data for SPY | 2016-04-22 18:51:19 SPY Monthly #4 | Reloading chart. | 2016-04-22 18:51:19 IQFeed | Using primary service for historical data for SPY | 2016-04-22 18:51:19 SPY Monthly #11 | Reloading chart. | 2016-04-22 18:51:19 IQFeed | Using primary service for historical data for SPY | 2016-04-22 18:51:19 IQFeed | Level 2 port reports server is disconnected. | 2016-04-22 23:26:30 IQFeed | Level 1 system message: SERVER DISCONNECTED | 2016-04-22 23:26:30 IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2016-04-22 23:26:30 Connection to the external service has been lost. | 2016-04-22 23:26:30 Socket (223) | Shutdown and closed. | 2016-04-22 23:26:31 IQFeed | Disconnected from Level 2 port. | 2016-04-22 23:26:31 Socket (222) | Shutdown and closed. | 2016-04-22 23:26:31 IQFeed | Disconnected from Lookup port. | 2016-04-22 23:26:31 Socket (221) | Shutdown and closed. | 2016-04-22 23:26:31 IQFeed | Disconnected from Level 1 port. | 2016-04-22 23:26:31 Socket (220) | Shutdown and closed. | 2016-04-22 23:26:31 IQFeed | Disconnected from Admin port. | 2016-04-22 23:26:31 IQFeed | Disconnected. | 2016-04-22 23:26:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 23:26:31 IQFeed | Connecting. | 2016-04-22 23:26:34 IQFeed | Connecting to Admin port 9300 | 2016-04-22 23:26:34 Socket (273) | Connected. | 2016-04-22 23:26:37 IQFeed | Connected to Admin port. | 2016-04-22 23:26:37 Notice: Detected that the system has resumed from a low-power state. | 2016-04-22 23:26:51 Re-connecting to the Data/Trading service. | 2016-04-22 23:26:51 Socket (273) | Shutdown and closed. | 2016-04-22 23:26:51 IQFeed | Disconnected from Admin port. | 2016-04-22 23:26:51 IQFeed | Disconnected. | 2016-04-22 23:26:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-22 23:26:51 IQFeed | Connecting. | 2016-04-23 12:19:32 IQFeed | Connecting to Admin port 9300 | 2016-04-23 12:19:32 Socket (276) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-04-23 12:19:34 Socket (276) | Shutdown and closed. | 2016-04-23 12:19:34 IQFeed | Disconnected from Admin port. | 2016-04-23 12:19:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-23 12:19:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-23 12:19:34 Starting DTN IQ Feed interface software. | 2016-04-23 12:19:34 IQFeed | Disconnected. | 2016-04-23 12:19:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-23 12:19:34 IQFeed | Connecting. | 2016-04-23 12:19:37 IQFeed | Connecting to Admin port 9300 | 2016-04-23 12:19:37 Socket (277) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-04-23 12:19:38 Socket (277) | Shutdown and closed. | 2016-04-23 12:19:38 IQFeed | Disconnected from Admin port. | 2016-04-23 12:19:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-04-23 12:19:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-04-23 12:19:38 Starting DTN IQ Feed interface software. | 2016-04-23 12:19:38 IQFeed | Disconnected. | 2016-04-23 12:19:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-23 12:19:38 IQFeed | Connecting. | 2016-04-23 12:19:41 IQFeed | Connecting to Admin port 9300 | 2016-04-23 12:19:41 Socket (278) | Connected. | 2016-04-23 12:19:41 IQFeed | Connected to Admin port. | 2016-04-23 12:19:41 AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2016-04-23 12:19:42 AdminMessage: S,STATS,66.112.156.226,60004,500,0,2,0,0,0,Apr 23 12:19PM,,Connected,5.2.0.9,ptrhbg1,0.00,0.0,0,0.06,0.0,0, | 2016-04-23 12:19:42 IQFeed | Connecting to Level 1 port 5009 | 2016-04-23 12:19:42 Socket (279) | Connected. | 2016-04-23 12:19:42 IQFeed | Connected to Level 1 port. | 2016-04-23 12:19:42 IQFeed | Connecting to Lookup port 9100 | 2016-04-23 12:19:42 IQFeed | Connecting to Level 2 port (9200)... | 2016-04-23 12:19:42 Socket (280) | Connected. | 2016-04-23 12:19:42 IQFeed | Connected to Historical Data port. | 2016-04-23 12:19:42 IQFeed | Connected to data server. | 2016-04-23 12:19:42 Socket (281) | Connected. | 2016-04-23 12:19:42 IQFeed | Connected to Level 2 port. | 2016-04-23 12:19:42 IQFeed | Using primary service for historical data for SPY | 2016-04-23 12:19:42 IQFeed | Starting real-time market data updates for: SPY. ID: 1 | 2016-04-23 12:19:42 HD Request # 28 | Downloading Historical Daily chart data for SPY. Starting date: 2016-04-20. Service: dtn | 2016-04-23 12:19:42 HD Request # 28 | Requesting 5 days of historical daily data. RequestID: 27 | 2016-04-23 12:19:42 IQFeed | Starting real-time market data updates for: MSFT. ID: 2 | 2016-04-23 12:19:42 IQFeed | Using primary service for historical data for MSFT | 2016-04-23 12:19:42 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2016-04-23 12:19:42 IQFeed | Starting real-time market data updates for: HRL. ID: 3 | 2016-04-23 12:19:42 IQFeed | Using primary service for historical data for HRL | 2016-04-23 12:19:42 Intraday data recording state for symbol HRL is set to download 'Pending'. | 2016-04-23 12:19:42 IQFeed | Starting real-time market data updates for: @ES#. ID: 4 | 2016-04-23 12:19:42 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 12:19:42 Intraday data recording state for symbol @ES# is set to download 'Pending'. | 2016-04-23 12:19:42 IQFeed | Starting real-time market data updates for: VXX. ID: 5 | 2016-04-23 12:19:42 IQFeed | Using primary service for historical data for VXX | 2016-04-23 12:19:42 Intraday data recording state for symbol VXX is set to download 'Pending'. | 2016-04-23 12:19:42 IQFeed | Starting real-time market data updates for: CORN. ID: 6 | 2016-04-23 12:19:42 IQFeed | Using primary service for historical data for CORN | 2016-04-23 12:19:42 Intraday data recording state for symbol CORN is set to download 'Pending'. | 2016-04-23 12:19:42 IQFeed | Starting real-time market data updates for: SGG. ID: 7 | 2016-04-23 12:19:42 IQFeed | Using primary service for historical data for SGG | 2016-04-23 12:19:42 Intraday data recording state for symbol SGG is set to download 'Pending'. | 2016-04-23 12:19:42 IQFeed | Starting real-time market data updates for: JO. ID: 8 | 2016-04-23 12:19:42 IQFeed | Using primary service for historical data for JO | 2016-04-23 12:19:42 Intraday data recording state for symbol JO is set to download 'Pending'. | 2016-04-23 12:19:42 IQFeed | Starting real-time market data updates for: FXC. ID: 9 | 2016-04-23 12:19:42 IQFeed | Using primary service for historical data for FXC | 2016-04-23 12:19:42 Intraday data recording state for symbol FXC is set to download 'Pending'. | 2016-04-23 12:19:42 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 12:19:42 IQFeed Level 2 error: Account not authorized for Level II | 2016-04-23 12:19:42 IQFeed | Level 2 protocol is 5.0. | 2016-04-23 12:19:42 IQFeed | Level 1 system message: KEY | 2016-04-23 12:19:42 IQFeed | Level 1 system message: SERVER CONNECTED | 2016-04-23 12:19:42 IQFeed | Level 1 system message: IP | 2016-04-23 12:19:42 IQFeed | Level 1 system message: CUST | 2016-04-23 12:19:42 HD Request # 28 | Receiving Daily data for SPY | 2016-04-23 12:19:44 HD Request # 28 | Receiving historical Daily data for SPY starting at 2016-04-20 | 2016-04-23 12:19:44 HD Request # 28 | Writing historical Daily data to the file SPY.dly | 2016-04-23 12:19:44 HD Request # 28 | Received 5 records from 2016-04-20 00:00:00 to 2016-04-22 00:00:00 (3.0 days) and wrote 3 records for SPY | 2016-04-23 12:19:44 HD Request # 28 | Daily download COMPLETE for SPY. Completion time: 2s. Unique request ID: 27 | 2016-04-23 12:19:44 Removed historical data download ID 27 | 2016-04-23 12:19:44 Delaying start of download for MSFT | 2016-04-23 12:19:44 SPY Monthly #11 | Reloading chart. | 2016-04-23 12:19:44 IQFeed | Using primary service for historical data for SPY | 2016-04-23 12:19:44 SPY Monthly #4 | Reloading chart. | 2016-04-23 12:19:44 IQFeed | Using primary service for historical data for SPY | 2016-04-23 12:19:44 SPY Monthly #4 | Reloading chart. | 2016-04-23 12:19:45 IQFeed | Using primary service for historical data for SPY | 2016-04-23 12:19:45 SPY Monthly #4 | Reloading chart. | 2016-04-23 12:19:45 IQFeed | Using primary service for historical data for SPY | 2016-04-23 12:19:45 SPY Monthly #11 | Reloading chart. | 2016-04-23 12:19:45 IQFeed | Using primary service for historical data for SPY | 2016-04-23 12:19:45 SPY Monthly #11 | Reloading chart. | 2016-04-23 12:19:45 IQFeed | Using primary service for historical data for SPY | 2016-04-23 12:19:45 HD Request # 29 | Downloading Intraday chart data for MSFT to the file MSFT.scid. Service: dtn | 2016-04-23 12:19:47 HD Request # 29 | Download start Date-Time: 2016-04-22 19:56:22.000 | 2016-04-23 12:19:47 HD Request # 29 | Requesting Tick data beginning at 2016-04-22 19:56:22 US Eastern Time. | 2016-04-23 12:19:47 HD Request # 29 | Receiving historical Intraday Tick data for MSFT | 2016-04-23 12:19:47 HD Request # 29 | Receiving Intraday data for MSFT starting at 2016-04-22 19:56:22 | 2016-04-23 12:19:47 HD Request # 29 | Timestamp of first Intraday data file record written: 2016-04-22 19:56:22 | 2016-04-23 12:19:47 HD Request # 29 | Received 1 record from 2016-04-22 19:56:22 to 2016-04-22 19:56:22 (0.0 seconds) and wrote 1 record for MSFT | 2016-04-23 12:19:47 HD Request # 29 | Intraday download COMPLETE for MSFT. Completion time: 1s. Unique request ID: 28 | 2016-04-23 12:19:47 Removed historical data download ID 28 | 2016-04-23 12:19:47 Real-time Intraday chart data file updates started for MSFT | 2016-04-23 12:19:47 Opened cached Intraday file: C:\SierraChart\Data\MSFT.scid | 2016-04-23 12:19:47 Intraday chart data file opened for MSFT | 2016-04-23 12:19:47 HD Request # 30 | Downloading Intraday chart data for HRL to the file HRL.scid. Service: dtn | 2016-04-23 12:19:47 HD Request # 30 | Download start Date-Time: 2016-04-22 19:33:20.000 | 2016-04-23 12:19:47 HD Request # 30 | Requesting Tick data beginning at 2016-04-22 19:33:20 US Eastern Time. | 2016-04-23 12:19:47 HD Request # 30 | Receiving historical Intraday Tick data for HRL | 2016-04-23 12:19:47 HD Request # 30 | Receiving Intraday data for HRL starting at 2016-04-22 19:33:20 | 2016-04-23 12:19:47 HD Request # 30 | Timestamp of first Intraday data file record written: 2016-04-22 19:33:20 | 2016-04-23 12:19:47 HD Request # 30 | Received 1 record from 2016-04-22 19:33:20 to 2016-04-22 19:33:20 (0.0 seconds) and wrote 1 record for HRL | 2016-04-23 12:19:47 HD Request # 30 | Intraday download COMPLETE for HRL. Completion time: 0s. Unique request ID: 29 | 2016-04-23 12:19:47 Removed historical data download ID 29 | 2016-04-23 12:19:47 Real-time Intraday chart data file updates started for HRL | 2016-04-23 12:19:47 Opened cached Intraday file: C:\SierraChart\Data\HRL.scid | 2016-04-23 12:19:47 Intraday chart data file opened for HRL | 2016-04-23 12:19:47 HD Request # 31 | Downloading Intraday chart data for @ES# to the file @ES#.scid. Service: dtn | 2016-04-23 12:19:47 HD Request # 31 | Download start Date-Time: 2016-04-22 16:59:59.000 | 2016-04-23 12:19:47 HD Request # 31 | Requesting Tick data beginning at 2016-04-22 16:59:59 US Eastern Time. | 2016-04-23 12:19:47 HD Request # 31 | Receiving historical Intraday Tick data for @ES# | 2016-04-23 12:19:48 HD Request # 31 | Receiving Intraday data for @ES# starting at 2016-04-22 16:59:59 | 2016-04-23 12:19:48 HD Request # 31 | Timestamp of first Intraday data file record written: 2016-04-22 16:59:59 | 2016-04-23 12:19:48 HD Request # 31 | Received 5 records from 2016-04-22 16:59:59 to 2016-04-22 16:59:59 (0.0 seconds) and wrote 5 records for @ES# | 2016-04-23 12:19:48 Added 4 Time and Sales records to Intraday data file for @ES# after download. | 2016-04-23 12:19:48 HD Request # 31 | Intraday download COMPLETE for @ES#. Completion time: 0s. Unique request ID: 30 | 2016-04-23 12:19:48 Removed historical data download ID 30 | 2016-04-23 12:19:48 Real-time Intraday chart data file updates started for @ES# | 2016-04-23 12:19:48 Opened cached Intraday file: C:\SierraChart\Data\@ES#.scid | 2016-04-23 12:19:48 Intraday chart data file opened for @ES# | 2016-04-23 12:19:48 HD Request # 32 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2016-04-23 12:19:48 HD Request # 32 | Download start Date-Time: 2016-04-22 19:59:22.000 | 2016-04-23 12:19:48 HD Request # 32 | Requesting Tick data beginning at 2016-04-22 19:59:22 US Eastern Time. | 2016-04-23 12:19:48 HD Request # 32 | Receiving historical Intraday Tick data for VXX | 2016-04-23 12:19:48 HD Request # 32 | Receiving Intraday data for VXX starting at 2016-04-22 19:59:22 | 2016-04-23 12:19:48 HD Request # 32 | Timestamp of first Intraday data file record written: 2016-04-22 19:59:22 | 2016-04-23 12:19:48 HD Request # 32 | Received 2 records from 2016-04-22 19:59:22 to 2016-04-22 19:59:22 (0.0 seconds) and wrote 2 records for VXX | 2016-04-23 12:19:48 HD Request # 32 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 31 | 2016-04-23 12:19:48 Removed historical data download ID 31 | 2016-04-23 12:19:48 Real-time Intraday chart data file updates started for VXX | 2016-04-23 12:19:48 Opened cached Intraday file: C:\SierraChart\Data\VXX.scid | 2016-04-23 12:19:48 Intraday chart data file opened for VXX | 2016-04-23 12:19:48 HD Request # 33 | Downloading Intraday chart data for CORN to the file CORN.scid. Service: dtn | 2016-04-23 12:19:48 HD Request # 33 | Download start Date-Time: 2016-04-22 16:00:00.000 | 2016-04-23 12:19:48 HD Request # 33 | Requesting Tick data beginning at 2016-04-22 16:00:00 US Eastern Time. | 2016-04-23 12:19:48 HD Request # 33 | Receiving historical Intraday Tick data for CORN | 2016-04-23 12:19:48 HD Request # 33 | Receiving Intraday data for CORN starting at 2016-04-22 16:00:00 | 2016-04-23 12:19:48 HD Request # 33 | Timestamp of first Intraday data file record written: 2016-04-22 16:00:00 | 2016-04-23 12:19:48 HD Request # 33 | Received 1 record from 2016-04-22 16:00:00 to 2016-04-22 16:00:00 (0.0 seconds) and wrote 1 record for CORN | 2016-04-23 12:19:48 HD Request # 33 | Intraday download COMPLETE for CORN. Completion time: 1s. Unique request ID: 32 | 2016-04-23 12:19:48 Removed historical data download ID 32 | 2016-04-23 12:19:48 Real-time Intraday chart data file updates started for CORN | 2016-04-23 12:19:48 Opened cached Intraday file: C:\SierraChart\Data\CORN.scid | 2016-04-23 12:19:48 Intraday chart data file opened for CORN | 2016-04-23 12:19:48 HD Request # 34 | Downloading Intraday chart data for SGG to the file SGG.scid. Service: dtn | 2016-04-23 12:19:48 HD Request # 34 | Download start Date-Time: 2016-04-22 15:56:37.000 | 2016-04-23 12:19:48 HD Request # 34 | Requesting Tick data beginning at 2016-04-22 15:56:37 US Eastern Time. | 2016-04-23 12:19:48 HD Request # 34 | Receiving historical Intraday Tick data for SGG | 2016-04-23 12:19:48 HD Request # 34 | Receiving Intraday data for SGG starting at 2016-04-22 15:56:37 | 2016-04-23 12:19:48 HD Request # 34 | Timestamp of first Intraday data file record written: 2016-04-22 15:56:37 | 2016-04-23 12:19:48 HD Request # 34 | Received 1 record from 2016-04-22 15:56:37 to 2016-04-22 15:56:37 (0.0 seconds) and wrote 1 record for SGG | 2016-04-23 12:19:48 HD Request # 34 | Intraday download COMPLETE for SGG. Completion time: 0s. Unique request ID: 33 | 2016-04-23 12:19:48 Removed historical data download ID 33 | 2016-04-23 12:19:48 Real-time Intraday chart data file updates started for SGG | 2016-04-23 12:19:48 Opened cached Intraday file: C:\SierraChart\Data\SGG.scid | 2016-04-23 12:19:48 Intraday chart data file opened for SGG | 2016-04-23 12:19:48 HD Request # 35 | Downloading Intraday chart data for JO to the file JO.scid. Service: dtn | 2016-04-23 12:19:48 HD Request # 35 | Download start Date-Time: 2016-04-22 16:03:12.000 | 2016-04-23 12:19:48 HD Request # 35 | Requesting Tick data beginning at 2016-04-22 16:03:12 US Eastern Time. | 2016-04-23 12:19:48 HD Request # 35 | Receiving historical Intraday Tick data for JO | 2016-04-23 12:19:48 HD Request # 35 | Receiving Intraday data for JO starting at 2016-04-22 16:03:12 | 2016-04-23 12:19:48 HD Request # 35 | Timestamp of first Intraday data file record written: 2016-04-22 16:03:12 | 2016-04-23 12:19:48 HD Request # 35 | Received 2 records from 2016-04-22 16:03:12 to 2016-04-22 16:03:12 (0.0 seconds) and wrote 2 records for JO | 2016-04-23 12:19:48 HD Request # 35 | Intraday download COMPLETE for JO. Completion time: 0s. Unique request ID: 34 | 2016-04-23 12:19:48 Removed historical data download ID 34 | 2016-04-23 12:19:48 Real-time Intraday chart data file updates started for JO | 2016-04-23 12:19:48 Opened cached Intraday file: C:\SierraChart\Data\JO.scid | 2016-04-23 12:19:48 Intraday chart data file opened for JO | 2016-04-23 12:19:48 HD Request # 36 | Downloading Intraday chart data for FXC to the file FXC.scid. Service: dtn | 2016-04-23 12:19:48 HD Request # 36 | Download start Date-Time: 2016-04-22 16:00:00.000 | 2016-04-23 12:19:48 HD Request # 36 | Requesting Tick data beginning at 2016-04-22 16:00:00 US Eastern Time. | 2016-04-23 12:19:48 HD Request # 36 | Receiving historical Intraday Tick data for FXC | 2016-04-23 12:19:48 HD Request # 36 | Receiving Intraday data for FXC starting at 2016-04-22 16:00:00 | 2016-04-23 12:19:48 HD Request # 36 | Timestamp of first Intraday data file record written: 2016-04-22 16:00:00 | 2016-04-23 12:19:48 HD Request # 36 | Received 1 record from 2016-04-22 16:00:00 to 2016-04-22 16:00:00 (0.0 seconds) and wrote 1 record for FXC | 2016-04-23 12:19:48 HD Request # 36 | Intraday download COMPLETE for FXC. Completion time: 0s. Unique request ID: 35 | 2016-04-23 12:19:48 Removed historical data download ID 35 | 2016-04-23 12:19:48 Real-time Intraday chart data file updates started for FXC | 2016-04-23 12:19:48 Opened cached Intraday file: C:\SierraChart\Data\FXC.scid | 2016-04-23 12:19:48 Intraday chart data file opened for FXC | 2016-04-23 12:19:48 HD Request # 37 | Downloading Historical Daily chart data for @ES#. Starting date: 2016-04-20. Service: dtn | 2016-04-23 12:19:48 HD Request # 37 | Requesting 5 days of historical daily data. RequestID: 36 | 2016-04-23 12:19:48 HD Request # 37 | Receiving Daily data for @ES# | 2016-04-23 12:19:49 HD Request # 37 | Receiving historical Daily data for @ES# starting at 2016-04-20 | 2016-04-23 12:19:49 HD Request # 37 | Writing historical Daily data to the file @ES#.dly | 2016-04-23 12:19:49 HD Request # 37 | Received 5 records from 2016-04-20 00:00:00 to 2016-04-22 00:00:00 (3.0 days) and wrote 3 records for @ES# | 2016-04-23 12:19:49 HD Request # 37 | Daily download COMPLETE for @ES#. Completion time: 0s. Unique request ID: 36 | 2016-04-23 12:19:49 Removed historical data download ID 36 | 2016-04-23 12:19:49 @ES# Monthly #1 | Reloading chart. | 2016-04-23 12:19:49 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 12:19:49 @ES# Weekly #2 | Reloading chart. | 2016-04-23 12:19:49 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 12:19:49 @ES# Monthly #1 | Reloading chart. | 2016-04-23 12:19:49 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 12:19:49 @ES# Monthly #1 | Reloading chart. | 2016-04-23 12:19:49 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 12:19:49 @ES# Weekly #2 | Reloading chart. | 2016-04-23 12:19:49 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 12:19:49 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:10:13 HD Request # 38 | Downloading Historical Daily chart data for @ES#. Starting date: 1966-04-24. Service: dtn | 2016-04-23 14:10:13 HD Request # 38 | Requesting 18263 days of historical daily data. RequestID: 37 | 2016-04-23 14:10:13 HD Request # 38 | Receiving Daily data for @ES# | 2016-04-23 14:10:14 HD Request # 38 | Receiving historical Daily data for @ES# starting at 1997-09-09 | 2016-04-23 14:10:14 HD Request # 38 | Writing historical Daily data to the file @ES#.dly | 2016-04-23 14:10:14 HD Request # 38 | Received 4722 records from 1997-09-09 00:00:00 to 2016-04-22 00:00:00 (18.6 years) and wrote 4722 records for @ES# | 2016-04-23 14:10:14 HD Request # 38 | Daily download COMPLETE for @ES#. Completion time: 1s. Unique request ID: 37 | 2016-04-23 14:10:14 Removed historical data download ID 37 | 2016-04-23 14:10:14 @ES# Monthly #1 | Reloading chart. | 2016-04-23 14:10:14 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:10:14 @ES# Weekly #2 | Reloading chart. | 2016-04-23 14:10:14 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:10:14 @ES# Monthly #1 | Reloading chart. | 2016-04-23 14:10:14 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:10:14 @ES# Monthly #1 | Reloading chart. | 2016-04-23 14:10:14 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:10:14 @ES# Weekly #2 | Reloading chart. | 2016-04-23 14:10:14 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:10:14 @ES# Monthly #1 | Reloading chart. | 2016-04-23 14:10:50 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:10:50 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:11:04 HD Request # 39 | Downloading Historical Daily chart data for @ES#. Starting date: 1966-04-24. Service: dtn | 2016-04-23 14:11:04 HD Request # 39 | Requesting 18263 days of historical daily data. RequestID: 38 | 2016-04-23 14:11:04 HD Request # 39 | Receiving Daily data for @ES# | 2016-04-23 14:11:05 HD Request # 39 | Receiving historical Daily data for @ES# starting at 1997-09-09 | 2016-04-23 14:11:05 HD Request # 39 | Writing historical Daily data to the file @ES#.dly | 2016-04-23 14:11:05 HD Request # 39 | Received 4722 records from 1997-09-09 00:00:00 to 2016-04-22 00:00:00 (18.6 years) and wrote 4722 records for @ES# | 2016-04-23 14:11:05 HD Request # 39 | Daily download COMPLETE for @ES#. Completion time: 0s. Unique request ID: 38 | 2016-04-23 14:11:05 Removed historical data download ID 38 | 2016-04-23 14:11:05 @ES# Monthly #1 | Reloading chart. | 2016-04-23 14:11:05 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:11:05 @ES# Monthly #1 | Reloading chart. | 2016-04-23 14:11:05 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:11:05 @ES# Monthly #1 | Reloading chart. | 2016-04-23 14:11:05 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:11:05 @ES# Weekly #2 | Reloading chart. | 2016-04-23 14:11:05 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:11:05 @ES# Weekly #2 | Reloading chart. | 2016-04-23 14:11:05 IQFeed | Using primary service for historical data for @ES# | 2016-04-23 14:11:05 |
| [2016-04-23 22:26:43] |
We can see that you re-downloaded data for @ES#. All of the data was received: HD Request # 39 | Received 4722 records from 1997-09-09 00:00:00 to 2016-04-22 00:00:00 (18.6 years) and wrote 4722 records for @ES# | 2016-04-23 14:11:05
HD Request # 39 | Daily download COMPLETE for @ES#. Completion time: 0s. Unique request ID: 38 | 2016-04-23 14:11:05 Go to the historical chart for that symbol and select Chart >>Chart Settings. What is the Days to Load setting set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-24 17:48:15] |
| User71822 - Posts: 24 |
The "Days to load" was set to 4380. I tried to reset it to 20,000 but received no additional data. In fact, there are only approximately 250 bars of data loaded.
| [2016-04-24 21:07:51] |
In the case of a monthly chart, since the ES futures data starts in 1997 there will only be 224 bars: http://www.sierrachart.com/image.php?Image=1461532047499.png This contract did not exist before then. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-25 16:21:19] |
That makes sense. But what about MSFT (went public in the mid 1980s) , and SPY? I can't get much more for either of those .
| [2016-04-25 16:25:39] |
Even for AT&T, I can only get data back to 1996. That's a little over 200 bars on a monthly chart.
| [2016-04-25 17:29:56] |
Contact DTN IQ Feed about this. We cannot help with it. Or consider using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed You will get more historical data with the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-25 17:30:36
| [2016-04-26 14:37:33] |
Thanks for your help. peter |
