Date/Time: Wed, 28 Oct 2026 20:36:47 +0000
sc.GetContainingIndexForSCDateTime function issue
View Count: 1097
[2016-04-13 14:33:38]
Johnny - Posts: 99
Hello, I'm having issues with the sc.GetContainingIndexForSCDateTime function, in some cases it doesn't return the correct index. Can I send you the chartbook that I'm using because it will be difficult to identify this otherwise?
Date Time Of Last Edit: 2016-04-13 15:56:11
[2016-04-13 16:41:54]
Johnny - Posts: 99
My apologies, I investigated this further and I found out that there was an error in the code that was causing these issues. There's nothing wrong with the function itself.
[2016-04-13 16:45:40]
We do not provide programming help. There cannot be any problems with this function.
It is extensively used in Sierra Chart. There either must be a misunderstanding or the problem is in your code.
Make sure there are no out of order timestamps in the chart. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s124
Date Time Of Last Edit: 2016-04-13 16:46:30
