Date/Time: Wed, 28 Oct 2026 20:36:47 +0000
Wrong Timestamp on X-axis
View Count: 1095
| [2016-04-12 22:53:46] |
| User636679 - Posts: 32 |
Hello, See attached screenshot. The TPO charts do not show the correct time on the x axis. E.g. the ES chart shows one profile for RTH and one for ETH (correctly so), however, the time shown for the RTH profile begins at 7:30 and only calculates seconds? So by the end of the RTH profile the time-stamp is 7:30.08. Same for the ETH profile, begins at 16:00 and ends at 16:00.13. Same with all my TPO charts. No problems with the VP charts, just TPO. Again, my oil TPO chart begins correctly begins at 16:00 but ends (at the completion of the profile) at 16:00.16. Need a fix - please advise. Thank you! |
| [2016-04-12 23:01:19] |
This is expected and we are going to prepare documentation later today to explain the details of this. For a TPO Profile Chart only the starting Date-Time for the profile that you actually see displayed along the bottom of the chart is what is relevant. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-13 09:43:03] |
Thank you for the reply.
| [2016-04-13 16:23:08] |
Here is the relevant documentation: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#TPOChartTimeScale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-13 18:17:44] |
Perfect - thank you!
