Date/Time: Wed, 28 Oct 2026 20:36:45 +0000
stop order and IB
View Count: 917
| [2016-04-12 15:55:20] |
| Stephan908 - Posts: 46 |
Hi, Can you guys tell me what I'm doing wrong? When I place a buy stop order in Sierra with IB, it will fill a couple cents higher than when I place the order directly on IB TWS. Let's say I want to do a buy stop with JNPR @ 22.65. If I place the order with Sierra DOM, I will fill me @ 22.69. If I do the same order with TWS, I get a 22.67 fill. Is there a setting in Sierra that I need to adjust? Thanks for your help. |
| [2016-04-12 17:45:01] |
Refer to this section: Interactive Brokers Trading Service: Interactive Brokers Stop Order Trigger Method Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
