Date/Time: Sat, 31 Oct 2026 18:07:50 +0000
Global cursor + sign color change
View Count: 1663
[2016-04-12 00:43:36]
User632496 - Posts: 6
Is it possible to change the color of global + cursor. It is blending with my dark grey background and can only be seen when u click left mouse button to show cross hair which is blue color in my charts.
[2016-04-12 02:22:51]
This can only be controlled through the operating system and is documented here:
Chart Drawing Tools: Controlling the Type of Pointer Displayed When Using Drawing Tools
[2022-03-25 01:55:09]
User341791 - Posts: 4
The documentation in the link describes how to change the type, not the color. It must be controlled in SC since it shows in different colors on different charts.
[2022-03-25 14:03:57]
To change the color of the '+', which is the operating system pointer, you need to go through the Operating System. On Windows 10, you would elect "Settings >> Devices >> Mouse >> Adjust Mouse and Cursor Size", then you can select the color on that page.
