Date/Time: Wed, 28 Oct 2026 20:36:45 +0000
Countdown timer position
View Count: 1345
| [2016-04-11 14:31:23] |
| AndyL - Posts: 119 |
I want to display the timer in the bottom right of the chart. When i set "Display in fill space" to No and "Use current price for vertical position" to No, the Initial horizontal/vertical position inputs dont appear to work (position of the timer doesnt cahnge when i alter the inputs). Any ideas? |
| [2016-04-11 17:09:18] |
To move the Countdown Timer, refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s201_MovingCountdownTimer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
