Date/Time: Wed, 28 Oct 2026 20:36:40 +0000
slow k one bar ago
View Count: 1156
| [2016-04-07 16:17:17] |
| User170575 - Posts: 221 |
=and(id3.sg1[-1]<id3.sg2[-1],C>=h[-1], id3.sg1<100[-1]) Hi---id3.sg1 references the slow k of a slow stochastic study---works just fine until I reference one bar ago [-1]. What am I missing? Many thanks, Cy |
| [2016-04-07 17:47:38] |
All we can say is that using [-1] is valid.
| [2016-04-08 13:39:12] |
Sorry, I am stuck--- Here is a link to the chart: http://www.sierrachart.com/image.php?Image=1460122302484.png ID2.SG1 references the Slow %k This works: =and(id2.sg1>0) This does not: =and(id2.sg1>0[-1]) Thanks---and have a nice weekend. Cy |
| [2016-04-08 18:49:20] |
What exactly are you trying to do? The underlined part of the formula does not make sense: =and(id2.sg1 > 0[-1]) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-09 00:49:15] |
I am just trying to test the formula...id2.sg1 is the slow k of the slow sto study... if referencing the current bar The formula works fine.... all bars turn chartreuse ... so I tested it one bar ago using -1....it does not work.... In other words the range on a stochastic is 0 - 100 ...so it should alert nearly every bar which it does if referencing the current bar... but no cigar if looking at the previous bar. Am I not referencing one bar ago correctly? |
| [2016-04-09 11:36:24] |
I see my problem.... thank you
