Date/Time: Wed, 28 Oct 2026 20:36:45 +0000
Trading Multiple Contracts
View Count: 1546
| [2016-04-06 18:42:01] |
| gmorgan111 - Posts: 121 |
I want to trade multiple contracts and am having trouble finding the instructions to set this up. If I want to trade 2 contracts with the same entry but different stops can you send me the link that explains how to set this up Thanks |
| [2016-04-06 19:22:38] |
| Futurestrader77 - Posts: 126 |
Hi, I saw your question. Here can you find what you are looking for: http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html You can simply add stops and targets. Date Time Of Last Edit: 2016-04-06 19:24:28
| [2016-04-06 19:43:36] |
Here is the documentation: Attached Orders Here is the documentation for the specific example you are looking for: http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#AttachedOrdersExample2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-06 19:45:25] |
The second link we gave in the prior post does not explain what you want. You need to use 2 separate stops each in a separate OCO Group. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-06 22:49:33] |
Thanks for the help. I am unable to follow the instructions I guess. I still get a message that says Target/Stops NoMatch. Can you just send me the steps to set up trading with two contracts each with a different target but each with the same stop. The instructions do not give an example using multiple contracts with different targets Thanks |
| [2016-04-07 06:36:53] |
We have attached a Trade Window configuration file for this. Here are instructions to use it: Basic Trading and the Trade Window: Using a Trade Window Configuration File Provided to You Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-07 06:37:15
| [2016-04-07 16:03:00] |
Thanks for giving me an attachment. I have not been able to open the attachment. Could you tell me how to open the attachment or what app or program I need to view the attachment Thanks |
| [2016-04-07 17:03:00] |
Right-click on it within your web browser and save it to this folder: C:\SierraChart\Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-12 15:30:33] |
I'm sorry I am making this so complicated but I did save the attachment to the data file in SierraChart I then try to open the chart in this file and it still will not open. Can you send this as another type of file or am I still doing something wrong. Thanks for your help |
| [2016-04-12 17:47:10] |
As long as you saved the file to this folder: C:\SierraChart\Data You can then use it by following the instructions here: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
