Date/Time: Wed, 28 Oct 2026 20:36:30 +0000
how to make scale on overlay
View Count: 1185
| [2016-04-06 16:05:03] |
| User15378 - Posts: 45 |
Hi there Is it possible to make the overlay on my region 1 not move about when i scroll or when the chart moves, i have a overlay thats very near to price and i want to see when it starts moving before my market but i want it to be"attatched" to price at all times, and what i mean is i dont want it to move about the chart, i want it to just try keep followng my price chart and not be free moving. so the price and the overlay pretty much stay in the same kind of scale making it easy to see when there is a divergence. thanks very much |
| [2016-04-06 17:48:40] |
Make sure the Scale Range for the main price graph and the study are both set to "Automatic". Refer to the documentation here: Chart Scale and Scale Adjusting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-06 17:51:08] |
WHen i put the scale to auto on the overlay the price scrunches up and the overlay goes flat, i looked in the price scale and it is automatic? Not sure what is going wrong... |
| [2016-04-06 17:54:06] |
So they are both set to Auto yet the price is scrunched right up to the top of the chart and the overlay is in a line form its a straight line on the bottom of the chart. They are both in region 1. just to confirm Date Time Of Last Edit: 2016-04-06 17:56:34
| [2016-04-06 19:21:37] |
Therefore, based upon this information you cannot accomplish what you want.
| [2016-04-06 19:23:33] |
oh thats a pity, so there is no way to have a overlay not to move when on a price chart. can you possibly see if you can add this into a new update if possible? it would be great to have a overlay just be stationary with price instead of moving around when scrolling through the chart. |
| [2016-04-06 19:40:49] |
This cannot be added because it is a technical impossibility.
| [2016-04-06 19:43:35] |
ok i see. thanks for the help then. cheers |
