Date/Time: Tue, 17 Nov 2026 00:04:29 +0000
charts
View Count: 1149
| [2016-04-06 06:09:24] |
| User680113 - Posts: 17 |
charts don t work it ,when I try to change the bar period comes up with the message download failed,i can not download the actual version .
Date Time Of Last Edit: 2016-04-06 06:23:59
| [2016-04-06 06:23:09] |
We want to help you but we need to get correct information from you. The first thing we want you to tell us is what particular futures market do you want to chart? Just tell us one of them and then we will give you instructions on what to do. Do not post any attachments unless we request them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-06 06:23:31
| [2016-04-06 07:09:43] |
eurex symbol for bund stoxx
| [2016-04-06 07:12:02] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings After that open a chart for that symbol through File >> Find Symbol. There was a problem with the EUREX data feed and it is now all resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-06 07:12:58
| [2016-06-14 07:43:54] |
Charts ...Bund and Stoxx (Eurex) chart data is delayed CME (S&P)works fine
| [2016-06-14 07:47:27] |
We are aware of this. We are working on it now. It is a Barchart data problem. We are patching in a different feed but please just allow us a little time to get this done.
| [2016-06-14 08:20:05] |
The EUREX data feed is now working. We apologize for the issue. It was a Barchart server data problem. They have been notified about it. We are using an alternate data feed at this time. We will make it clear to them, that they need to do a much better job and this is quite serious because this is the second time in recent months this has happened. There is going to be some incomplete data today for the EUREX due to the data problem. Follow the instructions here to re-download the data where there is incomplete data in the chart: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart If there is any further problem, let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
