Date/Time: Wed, 28 Oct 2026 19:59:02 +0000
Pivot Points Daily - How to activate levels S/R6-10
View Count: 1244
| [2016-04-01 14:49:37] |
| 4646ed - Posts: 231 |
Pivot Points Daily, formula 0, draw style = Line, Line = dash-dot-dot, Name and Value Labels are checked. PP and levels R.5-R5 and S.5-S5 are visible on the chart, but other S and R levels below and above are not. How do I activate them? I find the study very useful. But why do you have the 6-10 levels if they can't be used? (refer to the following URL for another thread in this forum from last year:Pivot Point Levels | Post: 63875) Date Time Of Last Edit: 2016-04-01 14:51:28
| [2016-04-01 16:43:09] |
For Formula Type 0, we have added calculations all the way to support and resistance levels 10. This will be out in the next release.
| [2016-04-04 10:42:31] |
Great. Thanks. Am looking forward to it.
