Date/Time: Wed, 28 Oct 2026 19:58:48 +0000
Tile horizontally & vertically additions
View Count: 1209
| [2016-03-31 18:54:33] |
| User22396 - Posts: 191 |
pls add the functionality when you can: tile 4 windows vertically ( 4 across by 1 row high) tile 18 windows vertically (6 across by 3 rows high ...nice square boxes)...you already do vertical for 15 and 20 thanks |
| [2016-03-31 19:07:16] |
This is not something that we would add. You have to manually set this up.
| [2016-03-31 20:26:23] |
Yes I have been doing it manually for quite some time. I understand you are busy but was hoping it would not be that difficult to add in a later release. thanks
