Date/Time: Tue, 17 Nov 2026 00:14:34 +0000
connecting Point of controls in number bars?
View Count: 1263
[2016-03-31 15:24:57]
User60518 - Posts: 106
hello - is it possible to have a line connect the POC's with a line in the number bars? I can provide an image if required.
Date Time Of Last Edit: 2016-03-31 15:25:28
[2016-03-31 17:22:49]
You can do this with the Volume by Price study:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php
Specifically refer to the Draw Mode input:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#DrawMode
You will need to display the lines only. Set the Draw Style for the lines you do not want to display to "Ignore".
[2016-05-27 16:43:34]
Hello, not sure I explained myself- what I wold like to do is overlay a line connecting the high volume prices (POC's) in the number bars. I have manually drawn them in this image:
http://www.sierrachart.com/image.php?Image=1464367301367.png
Cheers
[2016-05-27 19:43:07]
You need to use the Volume by Price study:
http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php
Set these Inputs as follows:
http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#InputVolumeGraphPeriodType = Multiple Profiles Based on Bar Count
http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#NumOfBarsForBasedOnBarCount = 1
http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#DrawMode = * Lines Only
For more information, refer to:
http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#CalculatingDisplayingDevelopingPOC_VAHL_VWAP
