Date/Time: Wed, 28 Oct 2026 19:58:32 +0000
Drawings question
View Count: 932
| [2016-03-31 13:21:26] |
| Johnny - Posts: 99 |
Hello, I apply a custom study to real-time charts, is there a way to make ACSIL drawings appear only once?
| [2016-03-31 16:45:21] |
We do not understand the question. It sounds like there is a problem with the custom study itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-31 18:40:28] |
I have set some rules for each drawing in order to appear on the chart. However, with real-time charts, when the conditions are met for the most recent bar, the drawing gets drawn over and over again. Is there a way to stop this?
| [2016-04-01 05:35:47] |
Refer to: Using Drawing Tools From an Advanced Custom Study: Preventing More Than One Chart Drawing Per Chart Bar or More Drawings than Intended Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
