Date/Time: Mon, 16 Nov 2026 23:54:22 +0000
Spreadsheet functions INDIRECT & CONCATENATE examples
View Count: 1741
[2016-03-25 03:38:39]
User553714 - Posts: 186
I am trying to use a combination of concantenate to form a reference to a cell range from text i.e
=CONCATENATE("BC3:", "BC", TEXT(H54))
which returns BC3:BC7
I am then trying to use INDIRECT to use that text formed cell reference to return for example the sum of that range
=SUM(INDIRECT(CONCATENATE("BC3:", "BC", TEXT(H54)) ))
but I keep on getting #REF! or #SYNTAX!
Is it possible to use text ranges with SC spreadsheet function INDIRECT and can you please provide an example of how I can do this?
Regards
[2016-03-25 03:40:45]
We have to check but we do not think this is supported.
The errors you are getting confirm this.
[2016-03-25 09:11:20]
It would be great if you can add this functionality to allow INDIRECT to accept text cell range references? This is not urgent as I only had them in mind for a specific task and there are other work arounds. It would also be great if the change is logged in the SC version change-log which I regularly check to see if there is anything specific worth upgrading for.
REgards
[2016-06-27 16:57:36]
User316362 - Posts: 215
I agree. This would be nice to have. I can create a dynamic range and convert it to text but cannot find a way to work around the INDIRECT limitation of using just a cell reference. Any alternative ways to handle this?
for instance MAX(INDIRECT("AK1:AK10")) will not work.
I did find a workaround. So nevermind
Date Time Of Last Edit: 2016-06-27 17:07:27
[2016-06-27 19:20:38]
We will see if this is not difficult to add.
