Date/Time: Sat, 26 Sep 2026 23:26:01 +0000
How to get absolute value of data and how to use math functions in general in Sierra Chart
View Count: 1950
| [2016-03-23 08:04:56] |
| User972044 - Posts: 154 |
Hello there, Can you confirm how to get the absolute value of data. For example I want to get the absolute value of the bar height and currently I am using abs(sc.Open[sc.Index] - sc.Close[sc.Index]) and when I try to output it along with the index value of the bar to debug it, it is NOT working. This is what I am getting from the Message Log: Chart: AUD.USD-CASH-IDEALPRO 1 Min #1 | Study: Custom DLL Study | Bar height L is: 0.000000 at Index: -1073741824 | 2016-03-23 03:53:00 Why am I getting this gibberish for the Index value when in the code, I specified the index as sc.Index and 0 for the absolute value in the Message line? I inputted "#include <math.h>" and "#include <cmath>" at the beginning of my codes. Is this not correct anymore? If not, can you advise what library files should I have included? And also I am using other math functions like fmax() and fmin() to process the data as according to the C++ Reference website with the link that you have included in your documentation? Are those still correct? Please confirm. Thank you for your help. |
| [2016-03-23 08:32:04] |
Use: fabs(sc.Open[sc.Index] - sc.Close[sc.Index])
