Date/Time: Wed, 28 Oct 2026 19:08:10 +0000
TRAILING STOP AND TARGET
View Count: 1212
| [2016-03-22 19:22:07] |
| User82615 - Posts: 106 |
HELLO I HAVE DEVELOPED A TRADING SYSTEM THAS HAS AN ATTACHED TRAILING STOP ORDER AND AN ATTACHED TARGET ORDER BOTH AT THE SAME TIME BUT WHEN DOING BACKTESTING THE SYSTEM DOESN'T CALCULATE GOOD THE TARGET ATTACHED ORDER. SO MY QUESTION IS : IS IT POSSIBLE TO HAVE A TRADING SYSTEM THAT HAS AN ATTACHED TRAILING STOP ORDER AND A ATTACHED TARGER ORDER AT THE SAME TIME? THANK YOU VERY MUCH |
| [2016-03-22 19:25:27] |
We do not understand what is meant by this: BUT WHEN DOING BACKTESTING THE SYSTEM DOESN'T CALCULATE GOOD THE TARGET ATTACHED ORDER.
The answer to the question is yes.
