Date/Time: Wed, 28 Oct 2026 19:08:05 +0000
how to get alerts off fibonacci levels?
View Count: 1293
| [2016-03-20 21:18:18] |
| User48557 - Posts: 138 |
With the ''price retracement'' tool is there a way i can get a audio alert every time a level is touched ? If so what is the code and where do I insert it ? If this is not possible then how can I manually place a alert when a certain price level is reached and what would the code be?
| [2016-03-21 18:38:48] |
This is not supported as is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Alerts As an alternative you could use a Symbol Alert which lets you set a price based alert condition: Alerts Manager: Symbol Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
