Date/Time: Wed, 28 Oct 2026 19:08:52 +0000
Rearrange order of trade configurations
View Count: 1176
| [2016-03-19 14:10:40] |
| User705691 - Posts: 22 |
If you have a lot of different trade configurations that are particular to certain markets, it is annoying to have a disorganized list of trade configurations, especially if you need to trade quickly. Is it possible to customize the order of how the trade configurations appear in the drop down menu?
| [2016-03-19 17:50:23] |
It is sorted alphabetically. Is it not sorted in your case? When you select one of the items in the list you can press the letter key of the first letter of the Trade Window configuration that you want to use. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-19 17:50:40
| [2016-03-22 14:01:28] |
Thank you, this makes more sense to me now. Is there any way to configure hotkeys to quickly select a trade configuration instead of using the first letter?
| [2016-03-22 17:22:37] |
No, this is not supported.
