Date/Time: Wed, 28 Oct 2026 19:09:08 +0000
Control Bar problem
View Count: 1047
[2016-03-18 16:03:28]
User764215 - Posts: 2
I opened SierraChart and I didn't see normal Control Bar.
There was only one big green rectangle with info about connection, and big gray button to find new symbol.
I don't change anything since last time.
I tried customize Control Bar, but it's still dont work, I tried change Control Bar, and it's too didn't helps.
I delete SierraChart and install again new version, but still the same problem.
How I can fix it?
I applied "Use Default", clicked OK, but it's not working.
Print screen in attached files. Screen with 2 Control Bars. First with deleted few things, second with deafault config.
Regards
imageScreenshot_11.png / V - Attached On 2016-03-18 16:03:13 UTC - Size: 90.13 KB - 377 views
[2016-03-18 16:44:37]
What you need to do in this particular case is decrease the Size of the Control Bar Text font. Here are instructions:
https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html#Fonts
[2016-03-18 17:00:19]
I changed size, but this don't help me.
When I change font from Arial Narrow to Arial it's helps.
Thanks.
LP
[2016-03-18 17:08:18]
Here is the relevant documentation:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#ControlBarButtonsTooLarge
