Date/Time: Fri, 11 Sep 2026 18:58:23 +0000
Alert Manager Log - clearing with ASCIL
View Count: 1139
| [2016-03-18 03:39:43] |
| User553714 - Posts: 184 |
Hi, 1) Is there any way I can clear the Alert Manager log using ASCIL, I have had a look at the 451 list of functions but there was nothing obvious to use? Is it possible to gain this control somehow within an ASCIL function? 2) I am having a strange issue where the Alert chart links listed in my Alert Manager go to the next (+1) chart in my watchlist instead of the Symbol which triggered the alert? I think this may have something to do with me using sc.DataFile in a custom study to cycle between charts? If there is an easy fix you will be saving me some time. I really haven't finished thinking about this so if there is nothing obvious that springs to your mind I will continue my testing and post with a separate request with further details. Regards |
| [2016-03-18 03:57:53] |
1. This is not supported. 2. When using the Go to Chart function on the Alerts Log you will be taken to the chart that the Alert originated from and it will be set to the Symbol shown in the Alert line. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
