Date/Time: Wed, 28 Oct 2026 18:30:09 +0000
User Question - Toolbar Sizing
View Count: 1040
| [2016-03-15 16:19:38] |
Hi, I wanted to send you the graphic below, the customer installed 1380 and the tool bar expanded as below, I looked through the website, but did not see any discussions about this, can you please advise as to how to resize the toolbar?
Sierra Chart Support |
Private File Private File Private File |
| [2016-03-16 03:21:02] |
This must be caused by the Control Bar Text >> Font >> Size. Check the Size. Here are instructions: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html#Fonts Apparently it is too large. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
