Date/Time: Thu, 02 May 2024 05:00:12 +0000
Forward Curve
View Count: 3606
[2018-05-13 22:31:22] |
Letting you know a new Forward Curve study is finally going to be released in about a week or so.
[2018-05-13 22:34:28] |
Adam - Posts: 141 |
This is brilliant thanks Any screenshots to share? |
[2018-05-20 12:30:16] |
Adam - Posts: 141 |
Hi Im looking at the study so you have any instructions on use? i can help test Adam |
[2018-05-21 09:43:57] |
Rassitude - Posts: 33 |
How would one benefit from forward curve in day trading, short term trading? Thanks |
[2018-05-21 09:47:22] |
Adam - Posts: 141 |
This isnt this forum for that but this book is a starter https://www.amazon.co.uk/Guide-Spread-Trading-Futures-ebook/dp/B00DUDSEGQ/ref=sr_1_6?ie=UTF8&qid=1526895995&sr=8-6&keywords=spread+trading |
[2018-05-21 10:31:59] |
Cavalry3162 - Posts: 523 |
hello SC, for some reason its available already and i gave it a shot.. however, there seems to be an issue with selecting the date.. see attached mp4 however, thank you for bringing it now! best, Andreas |
Private File |
[2018-05-21 21:21:50] |
The forward curve study is not yet ready. It will not display anything. We will take care of the date list issue.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-21 21:22:07
[2018-06-01 16:36:48] |
Adam - Posts: 141 |
Hows the Forward curve study looking? is there rough data it will be usuable Cheers |
[2018-06-04 19:49:53] |
We are getting close to finishing it.
