Date/Time: Mon, 02 Nov 2026 04:31:04 +0000
Attached order at exactly price
View Count: 3579
[2013-07-03 06:41:31]
user54342 - Posts: 42
I would like to ask you how I can set attached orders at exactly price? When I used 962 version and modified attached orders it was at price what I set. So attached orders set at preice wheather if was slippage oŕ not.
I want to know it because of stop orders.When you get slippage at entry your attached orders are moved with slippage but I do not want it. I want attached orders at place where I set it.
Julius
Date Time Of Last Edit: 2013-07-03 13:49:14
[2013-07-03 13:48:20]
Do you understand what I mean?
Julius
[2013-07-03 22:36:01]
Yes, we know. What if after the parent order fills, you readjust to the stop order if necessary to get it exactly where you want?
[2013-07-04 05:30:31]
I do not understand your answere.
So you know how to set attaced oders(target, stop) at price wich never move nor if I get slippage? Or I have to move orders manually at my price after slippage on stop order?
Julius
[2013-07-05 13:26:43]
Is anybody here to answere me?
Thank you
Julius
Date Time Of Last Edit: 2013-07-05 13:26:50
[2013-07-05 20:57:55]
We are thinking about how best to accommodate your request. For now after the parent order fills, adjust the Stop order to exactly where you want it.
Date Time Of Last Edit: 2013-07-05 20:58:05
[2013-07-05 21:58:26]
It works in 963 version. But I had to upgrade it. It worked well. When I set order and modified attached ordres they than stop at price which I set. Even in the case when I got slippage.
But when I did not modify orders they moved like now.
And can you do it for target too?
I think you should give not just how many ticks offset but even exactly price.
Great day
Julius
Date Time Of Last Edit: 2013-07-05 22:00:24
[2013-07-11 09:15:20]
Have you got something new abot this issue?
Julius
[2013-07-13 13:05:03]
Please can you make it? Becasue now I have to sit all time i front of monitor when my order is filled than I can move attached orders too.
Thank you very much
Julius
P.S. Join somebody who is with me.
[2013-07-15 10:56:34]
In the next release we are going to add an option to the General Trade Settings to not modify the Attached Orders after a parent fill.
[2013-07-16 07:53:04]
This is now done in the latest release. Please check the notes for the latest version on the What's New page.
[2013-07-16 10:17:38]
Thank you very very much.
I will download it when it will be realease version not pre-realese. Than I will write review :-)
Thank you again in advance
Julius
[2013-07-16 18:07:19]
Hi
One more question. When it is enabled it will work like now. And when it is disabled it will work like I want. Do I understand it well?
Julius
[2013-07-16 18:42:55]
Yes. You will have no problems with the prerelease. We recommend updating now.
[2013-07-17 06:30:43]
TastyRisk - Posts: 119
In the case of CTS; does CTS handle the offset of attached orders off of initial actual primary fill with no re-pricing from Sierra based on actual fill?
Date Time Of Last Edit: 2013-07-17 06:32:54
[2013-07-17 06:38:12]
No.
[2013-07-17 20:28:00]
Oh, So I take it you're not supporting Auto-OCO support on CTS FiX API, or your answer would have been more verbose ?
"Price of Limit component of OCO. Must be entered as a differential value from the expected trade price of the Trigger order." @ http://www.ctsfutures.com/wiki/T4%20API%20FIX.AutoOCO%20Order.ashx
Date Time Of Last Edit: 2013-07-17 20:28:41
