Date/Time: Wed, 28 Oct 2026 19:08:28 +0000
Drawing rectangles with price labels from acsil
View Count: 1386
| [2016-03-10 23:11:20] |
| onnb - Posts: 666 |
with the manual drawing, I can select "Show Price Labels" - is there an acsil equivalent?
| [2016-03-11 02:53:44] |
We will see about this.
| [2016-03-11 03:17:42] |
| Al SC Developer - Posts: 434 |
In the next version you will be able to set s_UseTool.ShowPrice to non-zero value for rectangle highlights.
Date Time Of Last Edit: 2016-03-11 03:19:02
| [2016-03-20 18:14:58] |
| onnb - Posts: 666 |
Labels appear on left hand side - is there a way to define price labels on right hand side?
| [2016-03-22 16:20:32] |
Set UseToolData.TextAlignment to DT_RIGHT.
