Date/Time: Wed, 28 Oct 2026 17:49:59 +0000
Second instance of Sierra Chart
View Count: 929
| [2016-03-08 21:04:37] |
| toews&kane - Posts: 209 |
Hey there, Trying to figure this out, running a second instance of sierra chart and trying to run the spreadsheet system for trading. The spreadsheet is hanging like crazy. Brand new. Do we have performance issues with that? Second sierra instance piggy backing off of the first's data? Cheers |
| [2016-03-08 21:08:40] |
We see you are running version 1276. The current version of Sierra Chart is 1377. If you are using the version of Sierra Chart Old Spreadsheets that is no longer supported and if you are using the version with New Spreadsheets, then the new work versions have much higher performance with New Spreadsheets and you will need to update. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
