Date/Time: Wed, 28 Oct 2026 17:51:47 +0000
Highlight high # on Depth of Market
View Count: 982
| [2016-03-03 15:38:20] |
| AP - Posts: 117 |
Is there a way to highlight the lines with most pending orders on Depth of Market? Or another study with an analytical view of it? I tried Bid&Ask Depth bars and it did not quite get what I am looking for. Pls advise. |
| [2016-03-03 17:40:10] |
Have a look at using the DOM Graph: http://www.sierrachart.com/index.php?page=doc/doc_TradeMenu.html#DrawDOMGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-03 19:19:25] |
| AP - Posts: 117 |
Thanks - but guys can you please take a look at this section below it says - Chart >> Chart Settings >> DOM Graph under Trade >> Draw DOM Graph on Chart http://www.sierrachart.com/index.php?page=doc/doc_TradeMenu.html#DrawDOMGraph I just cannot find the option of DOM graph under chart settings. PLEASE HELP - THIS IS IMP TO ME. |
| [2016-03-03 19:22:32] |
| AP - Posts: 117 |
By the way, I can see the DOM on chart so my feed and service is all good. Just that I do not see other options like "Only Levels with Greatest Volume", etc.
| [2016-03-04 04:35:37] |
The documentation has now been updated: http://www.sierrachart.com/index.php?page=doc/doc_TradeMenu.html#DrawDOMGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
