Date/Time: Wed, 28 Oct 2026 17:49:44 +0000
Data Feed/Symbol for % of stocks above below Moving Average/Vwap
View Count: 1656
| [2016-03-02 15:31:46] |
| dd45 - Posts: 41 |
Can anyone tell me what the symbol or maybe which data feed I would need to activate to get charts up for the %age of stocks trading above vwap or moving averages?
| [2016-03-02 20:48:30] |
This can be done through a scan of all of the symbols on the particular exchanges that you want. It is time-consuming. And you need to have a list of all of those symbols. Sierra Chart does not have any way currently to automatically generate a list of all the symbols on the NYSE and NASDAQ. More information can be found here: http://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#Scanning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-02 20:48:42
