Date/Time: Wed, 28 Oct 2026 16:56:30 +0000
lock fill space above and below candles
View Count: 1160
| [2016-02-26 19:34:59] |
| markuz - Posts: 90 |
is there away to lock the fill space for above and below candles (x axis) i know you can lock the space between the current candle and y axis, however there are indicators that populate above and below candlesticks that get cutoff as the market populates. for example: always keep the highest forming candlestick 2 points below the top of the screen and 2 points above the bottom of the time axis. thanks. |
| [2016-02-26 19:43:29] |
This is not supported. However, refer to Interactive Scaling: Chart Scale and Scale Adjusting: Interactive Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
