Date/Time: Wed, 28 Oct 2026 16:56:25 +0000
Changing Keltner band middle band color in relation to separate moving averages
View Count: 1255
| [2016-02-26 18:45:47] |
| eayjee - Posts: 1 |
Hi, thanks for reading. I would like to change the color of the middle keltner MA to red when below 2 separately plotted moving averages, white when between them, and blue when above. I am very much non-technical when it comes to coding. Any help would be most appreciated. I am also interested in placing an indicator dot below/above a bar when it's volume exceeds the average of the last 6 bars by a factor of 1.618. Thanks in advance. |
| [2016-02-26 19:41:20] |
All we can do is say that this is supported by using the Color Bar Based on Alert Condition study. Refer to the documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 This is all the help we can provide. We do not provide formula programming help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-26 19:41:42
