Date/Time: Wed, 28 Oct 2026 16:56:28 +0000
Data fromTDameritrade
View Count: 995
[2016-02-26 00:03:26]
mogull - Posts: 40
Trying to get my sierra data from TD.
When I switch sources the bar goes green, says it's
connected, but no data is coming through.
I asked them and they said......
Good Morning,
Thank you for contacting us. Currently, SierraCharts is a supported partner of the TD Ameritrade API. If you can login to your TD Ameritrade account, you should be able to setup SierraCharts. You would not need individual access to this data feed as they already have a business relationship with us. If you have questions regarding SierraCharts software, you would need to reach out to them directly.
API Support Team
Can you tell me what else I might need to do on Sierra side?
[2016-02-26 00:45:45]
Tell us one of the symbols you want to get data for from TD Ameritrade.
