Date/Time: Wed, 28 Oct 2026 16:56:31 +0000
old data on my old HD
View Count: 1016
| [2016-02-25 19:33:33] |
| User61576 - Posts: 458 |
i replaced computers and i found i have tick data of some of my symbols archived in a different place than my current SC data folder the current file size is 650mb and the old on is 1.7g (it's SC format and not txt to import) also my old file is dated to 02/2015 and my new file has it's first record on 08-2014 so there is overlapping of data is there any way to import that old data into my current data folder? thanks Date Time Of Last Edit: 2016-02-25 19:36:13
| [2016-02-25 20:07:28] |
Just copy the Intraday data files. For instructions, refer to: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-25 20:13:49] |
i was not clear enough both files are for XG daat 1st file is 2011 till 02/2015 and 2nd file is 08/2014 till doday i want to make only 1 file |
| [2016-02-25 22:21:17] |
XG is an IQ Feed symbol for the EUREX DAX. The proper solution is to use the Sierra Chart Historical Data Service and open a chart for the DAX futures. Here are instructions: Sierra Chart Historical Data Service For a long-term chart, use the Continuous Futures Contract Feature. Refer to: Continuous Futures Contract Charts There is no way to combine the two files that you have into 1 because they have overlapping date ranges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-27 20:09:04] |
both data files are XG# so nothing to roll here I only want to attach both files together to have a 1 file from 2011 till today if i export from SC to txt file, than work on the file in notepad++ and than could i import all tick data file back to SC? |
| [2016-02-29 09:22:52] |
This can be done. Refer to this page: Exporting and Importing Intraday Data Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
