Date/Time: Wed, 28 Oct 2026 16:13:20 +0000
custom defined keyboard shortcuts > printout list?
View Count: 1582
| [2016-02-23 17:07:47] |
| User51760 - Posts: 108 |
Dear support team, is it possible to list custom defined keyboard shortcuts for printout to get a reference? Thank you, Best, Chris |
| [2016-02-23 17:12:17] |
No.
