Date/Time: Wed, 28 Oct 2026 16:13:36 +0000
MACD Fractional Input Data
View Count: 1136
| [2016-02-21 20:24:29] |
| sjkafeero - Posts: 21 |
How do I use frational input data (moving average length) for the MACD? For example, 8.10954 instead of just 8.Thanks
| [2016-02-21 20:26:15] |
This is not supported.
| [2016-02-21 20:28:10] |
However, you can create your own custom study to do what you require. You can take the existing MACD source code and modify it. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
