Date/Time: Wed, 28 Oct 2026 16:13:38 +0000
chart update only at close of time period
View Count: 1012
| [2016-02-18 17:58:19] |
| User757207 - Posts: 45 |
If I'm using 1 minute bars, how can I set the chart to only update the price bars at the close of each time period? That is, I don't need to see all the price action during the 1 minute period. I only need to see the bar at the close of 1 minute of time. Is this possible? |
| [2016-02-18 18:33:45] |
No, this is not supported.
