Date/Time: Fri, 11 Sep 2026 21:12:38 +0000
Volume Composite and daily VbP
View Count: 1335
[2016-02-15 16:56:31]
User815073 - Posts: 14
Hi, I am trying to build a chart that has both a long term volume by price profile and daily volume by price profiles but I am running into trouble when I am doing this with the ES, as the composite is in front of the daily profile, in other products like the eurodollar it works fine. If I could move the day over to the left just a bit it would help a lot. I am including a chart.
http://www.sierrachart.com/image.php?l=1455555318740.png
Thank You,
Jim
[2016-02-15 18:28:47]
Refer to the instructions here to align the long term Volume Profile to the far right side and create space on the right side:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#RightAligningVolProfilesWithSpaceOnRight
