Date/Time: Wed, 28 Oct 2026 15:32:22 +0000
exceeded number of logins
View Count: 1002
| [2016-02-14 04:57:26] |
| User38993 - Posts: 61 |
Hello I am trying to run exact same files on two different laptops, but once I login to one, the other one wouldn't login due to "exceeded number of logins" I am using AMP futures + Sierrachart package 3 + CQG Is there anyway I can run two copies on different computer? |
| [2016-02-15 10:02:53] |
You need to have a direct account to be able to run two copies of Sierra Chart at the same time: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
