Date/Time: Wed, 28 Oct 2026 15:31:52 +0000
Spreadsheet System for Trading - Static Columns
View Count: 1345
[2016-02-13 11:05:38]
User553714 - Posts: 186
I am finding Column-H very useful as it is a static (read/write) column (dose not recalculate and keeps user defined values/formula) and was wondering if there is anyway to add a 2nd static column beside this I.E to have two static columns side-by-side to allow me to set my own Settings Labels/Values similar to the Spreadsheet System for Trading Study Settings Labels/Values defined in columns J&K (which are not static).
I tried inserting a column before Column "I" but when the sheet re-calculated it re-inserted the labels of the old Column "I" into the new column "I" so I was left with the single static column "H".
If there is a way to insert a NEW static column can the same be done to insert a new static Row - say Row-2 to become static also?
REgards
[2016-02-13 18:11:32]
You cannot insert Columns or Rows like this.
You just need to use an available column towards the right side of the Sheet after the studies. Obviously there are a huge number of them available.
Date Time Of Last Edit: 2016-02-13 22:57:41
[2016-02-13 18:22:41]
Sawtooth - Posts: 4358
Cells E1:Z1...BR1 (depending on the Number of Formula Columns setting) are static cells also.
Columns to the right of the study output columns are static, but if you add a study, they will be overwritten.
