Date/Time: Wed, 28 Oct 2026 15:30:27 +0000
is it possible to color up and down closes?
View Count: 1097
| [2016-02-12 09:52:58] |
| User40520 - Posts: 62 |
I need HLC charts with green bar = green close and red bar = red close. Is this possible? There seems to be only one color choice and if that's the case can we have two colors please.
| [2016-02-12 11:46:34] |
Refer to: Graphics Settings You need to use the option: "Up/Down Coloring for OHLC Bars Based on Previous and Current Close". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
